I'm halfway? maybe more through mine right now, I initially recapped the power amp as it had a bad cap causing a weak channel, and I've since moved on to recap the power supply board and replace the filter caps.
The big difference maker was replacing the 2SC458 transistors in the pre-amp—it went from having a quite noticeable idle hiss to being virtually silent.
I've just received the caps for the preamp board, so that's next on my list, and I need to recap and replace transistors in the phone stage too.
So far it's been relatively easy—the biggest challenge was opening up the power amp board without breaking the diodes on the heat sink, I desoldered the diodes on the board side and opened it up like a book. Others have pointed out that a good approach is to desolder and pull the pins rather than unwrapping wires to get the board free from the chassis.
Edit just to add that it sounds great right now, it's my favorite of the amps I have around. And looks terrific too, especially with a wooden case.
