1962 stromber-carlson console sterio- help
Discussion in 'Tube Audio' started by stromberg721, Mar 22, 2011.
  1. stromberg721
    stromberg721 New Member
    5
    I have a large wood 1962 stromberg-carlson AM/FM radio with record player console model #. I am looking for more information on the rarity. AM/FM radio works but the record player, unfortunalty does not; I believe due to a bad switch. I have searched countless hours online for information and have not even found a picture of one. Is this a rare item?
    please help
    here is a picture i took of mine
  2. mibag6
    mibag6 Well-Known Member
    973
    Duluth, Mn
    Questions of value usually get bumped to Dollars and Sense forum. You'll probably get more info in the tube forum. Might want to edit out the value questions. It probably has a nice little push pull 6V6 stereo amp, can't tell you much else.
  3. stromberg721
    5
  4. Stromberg48
    Stromberg48 "Classic Chinese audio"
    60
    North East, Ohio
    looks like a record changer, Is that a record changer or a manual tt? My guess is this is a 63 or later model. a front pic would be nice.
  5. spaceman
    spaceman Registered Lunatic
    14,905
    Seattle
    That looks a bit different from either one I've messed with, but looks more like the one that had a SE 7408 amp, the ASR-110. My Penthouse is much longer, with a section on each side of the lid. If you can take off the back & grab pics of the amp & drivers, we can offer more help.
  6. century tek
    century tek Super Member
    2,699
    The Evergreen State
    That is the same as the one I picked up a few years back. Sinse you don't have a pic of the amp, its either the ASR-110 or ASR-120. The ASR-110 is single ended 7408's & the ASR-120 is push/pull 7408's. Both have the 7199 drivers and 6CA4 rectifier. I believe Tom Bavis has both schematics. I got my ASR-120 schematic from him.
  7. century tek
    2,699
    The Evergreen State
    Its a record changer. You can tell by the long spindle that's able to hold a stack. A manual TT usually does not have the long spindle or arm to hold the records, and/or the "REJ" option. That particular TT has the speed control as the outer knob, and off-on-rej as the inner round control.
  8. larryderouin
    larryderouin Do I get Food, Med's, or more gear this Month? Subscriber
    18,863
    Glen Burnie Md.
    The changer is a Voice of Music changer. IIRC it's a 12xx series unit. Lift it out and look for the model and serial #'s as outlined on the V-O-M site. They also have parts for the changer too.
    Larry
  9. stromberg721
    5
    more pics
    model number on the record player is
    MRS 4058
    148-000
    107
    67012148
    HERE ARE SOME MORE PICS
  10. larryderouin
    18,863
    Glen Burnie Md.
    your info from the changer doesn't match up with what VOM is saying.
    it's quite possible that S-C put their own info on it also.
    Here's the link you want to check on the changer http://www.thevoiceofmusic.com/do_i_have_vm.html
    Did it not come with legs??? It looks like the type that should have at least 7"or 8" legs.
  11. Tinkerbelle
    Tinkerbelle Everything in Moderation ------- Hudson Valley, NY Super Mod Subscriber
    6,051
    Hudson Valley, NY
  12. Thespeakerdude8
    Thespeakerdude8 AK Subscriber Subscriber
    2,037
    Not really, pretty standard Stromberg console. Nicer in some cases than some of the Magnavox's. Its in poor shape to be worth a lot of money, but is it worth fixing? Yeah! Finish work isn't too hard, and it probably just needs a few capacitors replaced. Would I dump a couple hundred into it? No.
  13. orthophonic
    orthophonic Super Member
    1,216
    Winter Park, florida
    The Record Changer is not VM, it is a Glaser Steers, these changers are rather unique in that the platter stops spinning before the record drops, then
    starts spinning again when the arm lands on the record.
    Nice looking Modern style console, would probably be an easy restore.
  14. KentTeffeteller
    23,058
    Athens, TN
    I agree you have a Glaser/Steers changer installed. The overarm and general styling does not appear to be V-M of the period. It's a much better than average console in sonics and build, only Fisher, Ampex or HH Scott are rivals here. Worth some love and restoration. The Stromberg-Carlson consoles are superb sounding and the better of the herd. :tresbon:
  15. larryderouin
    18,863
    Glen Burnie Md.
    I'll be damned. I coulda sworn it was a VOM. Learned something new today. (Boy am I in trouble......Old dogs, new tricks!)
    Larry
  16. tobyjuan
    tobyjuan New Member
    6
    Stromberg Carlson RP-721-WO
    Hi. I am new to restoring old consoles. I acquired a Stromberg Carlson RP-721-WO that I would like to get working. It is in really good shape but if I turn it on, there is a loud hum. I turned it off immediately. I would like to try replacing the amp capacitors but am having trouble identifying replacements. the large twist-lock can capacitor on the amp has these specs;
    40@450/30@350/15@350/50@25.
    I cannot cross-reference and of the substituted part from the manual. I see that CE Engineering makes replacements but not of the same specs. Can someone make a recommendation for a proper replacement?
    Would you suggest just replacing this first and then the smaller capacitors?
    The tubes are fine by all indications.
    Thanks!
  17. Tom Bavis
    Tom Bavis Audiophool Subscriber
    9,011
    Macedon NY
    The 50/35V section can be replaced by a small tubular cap. Actually, all of the caps in the can could be replaced by separate ones underneath, with the can left in place for appearance. 450V may be easier to find, and it's always OK to use a higher voltage cap if it fits. If you haven't been to my website yet, get the service info there: http://www.audiophool.com/MadeInRoch.html You're looking for the SR-130 tuner and ASR-110 amp.
  18. tobyjuan
    tobyjuan New Member
    6
    Thank you. I think I have found all of them at Mouser. I look forward to finding out if I can actually get everything working.
  19. vinyl fiend
    vinyl fiend Active Member
    346
    Newburgh, NY
    The record player is pretty. The amp is el rrroacholo.
  20. jaymanaa
    jaymanaa AK Subscriber Subscriber
    55,701
    OZ
    I bet he could cleaan it up and maybe use some spray galv or something on it. One thing I learned about S/C amps is the uglier they are, the better they sound.
