Flip69
I have found several threads that address stereo light issues. However, I have not found any clear answer to this situation. I am finishing up work on a 2245. The stereo light bulb is good. It comes on as it should in phono, aux, etc. It does not come on in FM. The FM alignment is definitely off a bit, e.g., 101.3 tunes in at closer to 100.3 on the dial. I do get stereo FM. That is clear when turning mono on and off. The meters seem to be working fine. However, the stereo light does not come on, even when tuned to the strongest stations.
I have an oscilloscope. However, I do not have the other gear I would need to attempt an alignment, even if I were inclined to do so (FM signal generator, etc.). I have not checked to see if someone in my area does alignments. Could bad alignment cause this problem? It seems like the issue would be signal strength, not whether the needle lines up to the right number on the dial. Different threads have referenced different adjustment to different trimmers, but nothing definitive. I have seen references to using compressed air to blow dust off the fins. At least one thread suggested that some models have a chip that plays a role in stereo light operation. Not sure if the 2245 is one of them.
How do I troubleshoot this? I don't want to simply start messing randomly with trimmers. It is not a huge deal, since everything else seems to be working as it should, including FM stereo. However, given all the other work I have done, It would be nice to get this working, if possible.
