As the owner of fine gear on both the tube and solid state side, I would be hesistant of saying that going for a monster receiver is the wrong move. Take for instance that MCS 3125 I mentioned in the prior response I had. I would not hesistate to say that is one of the finest sounding pieces of gear I have owned, modern or vintage, tube or solid state. It is not up there with the really big ones (though the manual makes no hesitation to say it is capable of over 200wpc at full volume). A good deal of these monster receivers are well designed as well. Spec for spec that MCS will still rival many top amps of today. I am fortunate enough to have a copy of the manual so I can compare it to other stuff should it ever cross my path. Hop over to the gallery and take a look at some of the internal shots of my Project One Mark 1500 or Fisher RS-1058 (the latter by no means a monster, a puny 40lb 90wpc unit). Even with the lousy photo you can still see how straighforward the signal path on that Fisher is on the amp boards. The Fisher RS-1060 goes so far as to double shield the internal signal carrying wiring (with cute little rubber boots where the extra insulation is split off and it connects to the RCA inputs). Are they really inviable options either? Granted there are some fetching rediculous prices but I snapped some big ones up under $100, going as low as $.01 for the Audiograph 2A100. One cent for a 100wpc (estimated, you can pretty much figure at least that based on the parts used but information on this company is non existant). That seems fair in my estimation. Actually the MCS 3125 is the only one I paid over $100 for, and to get that mint condition faceplate on that big one was well worth it. I would be more than glad to put some of these big receivers up against some of the competition. The results might be surprising.
