620 relay
jeffV
I am trying to replace the relay in my 620, it is numbered HC-2P- dc12v-f AP34219.
I have a brand new relay labeled HC2-HP-dc12v-f. AP3421f.
can I use this to replace the original?
If now where do I get the replacement?
relay went in just fine, but I am still not getting power to the relay, it never clicks over..multimeter teseted several resistors that appear to be in the relay circuit, but I cant seem to locate where the poer loss is coming from.
Relay works fine (sound out of the speakers) if you manually make the connection...
any thoughts??
Take a photo of C816 33µf/16vdc capacitor. Probably a small violet colored one with dark red lettering.
Oh BTW don't slip and short out adjacent pins or component leads. That will let the magic blue smoke loose.
Sure its not 80 mv? Are you sure your on the correct transistor ?. How about on the collector of TR804 ?
80 volts you should have parts smoking in that circuit.
83.4 mv on tr804 collector side. relay switches when I touch the lead to the collector side.
