First off thanks to everyone who chimed in on my last thread. I couldn't have fixed that unit without all your help.
I'm hoping to get some guidance on a new project. I have an 8080 that picked up on Craigslist. It's in pretty rough shape but I have it partially working. When I got it, it was missing the rear fuse cap and most of the fuses in the unit were the wrong values, and most were blown. I sourced a replacement fuse cap and replaced the fuses, along with the two fuses on the driver board that appears to be post fuse notice. I checked the fusible resistor values on the driver board and everything is close enough to in spec, but will eventually be replaced. After connecting my dim bulb tester I powered on the unit and everything looked good. I removed the DBT and biased the unit. I also checked the channel voltage while I was at it. I have deoxed all the switches and pots multiple times. I have one channel, the right channel, I just can't seem to get working regardless of input or switch selection. I have poked and prodded the switches, relay, and boards to see if I get any change but nothing so far. If I connect a phone to the main in I get audio out of both channels. If I remove the pre out main in jumpers, and use rca cables to rotate the jumper in the problem moves between channels.
Any help would be greatly appreciated.
Thanks
Mototo
Thanks
Mototo
