INTRODUCTION
And so we come to the last of Heath’s early Williamson offerings, the W-3AM. For reference, the previous two entries into this Heath saga can be found here:
http://audiokarma.org/forums/index.php?threads/regilding-the-gilded-lily-heaths-w-2m.767851/
http://audiokarma.org/forums/index.php?threads/from-the-frying-pan-into-the-fire-heaths-w-3m.769029/
As the title of this thread suggests, the W-3AM was in fact a new beginning for Heath’s high fidelity line of amplifiers. After the disastrous W-3M, Heath burned the midnight oil and wisely adopted measures of improved stability previously presented by others, that they had otherwise ignored up until that time. They went even further and introduced an additional new stability measure of their own to help ensure that the problems of the previous model were completely annihilated: Dubbed by Heath’s marketing department in succeeding models as the “Tweeter Saver”, the W-3AM was the first of their models to employ this feature (a Zobel network across the OPT secondary winding) to help ensure HF stability. Of course, the W-3AM sports the same genuine Acrosound UltraLinear transformer and basic circuit design as that of the W-3M. But the new model includes a number of measures designed to contain all the ill manners of the previous offering. They include:
1. Adding an input grid stopper resistor.
2. Adding a step network across the plate load resistor of the AF amplifier stage.
3. Reducing the value of the driver stage input coupling caps by a factor of 5.
4. Adding the aforementioned Zobel network across the 16Ω winding.
5. Reducing the NFB level employed.
All of these elements play a role in taming the untenable low and high frequency stability characteristics of the W-3M. It is from their application then, that the W-3AM was born, and the improvements they make are readily apparent, too. Consider the following:
1. The new design is stable with any level of capacitance added to any properly loaded tap.
2. In an unloaded condition, the new design can handle as much as .22 uF across the 16Ω tap, .15 uF across the 8Ω tap, and an unlimited amount of capacitance across the 4Ω tap.
3. new design demonstrates fast settling under pulsed conditions.
4. The new design is also stable enough at low frequencies when unloaded, although bounce increases, and settling slows significantly under pulsed conditions when unloaded.
This stability level is simply lightyears ahead of its predecessor’s, making for an amplifier that you don’t have to worry is going reach critical mass with the first little transient (musical or otherwise) that comes along. Of course, other things changed as well:
1. Frequency response is no longer ruler flat out to 100 kHz, but now follows the published curve quite closely, with a measured results of -.10 db @ 20kHz, -1 db @ 53kHz, -1.2 db @ 80kHz, -3 db @ 91kHz, and -5.0 db at 98kHz, as measured at the 16Ω tap. This will be discussed in greater detail in a little bit.
2. With the reduced NFB, full power total harmonic distortion takes a hit, but still turns in respectable performance measuring as: .76% THD at 20Hz at 24.01 watts RMS, .46% @ 1kHz @ 25.38 watts, and 1.60% @ 20kHz @ 23.77 watts. Maximum power output levels are unchanged from that of the W-3M.
3. IM Distortion also increases (basically doubling) to 1.25%
4. The reduced NFB significantly increases sensitivity as well, now requiring just under 1 volt (0.96 vac) to produce full power output.
5. The NFB level itself, while stated as being 18 db, actually measures only 16.6 db. When this is compared to the measured 21.5 db of the W-3M, it can be seen that the reduction is notable (cutting it almost in half), making it a significant element of Heath’s effort to improve overall stability. It is a basic principle that as NFB is increased, performance is also increased. But increasing amounts of feedback bring with it the potential for increased instability as well. This is particularly true with global NFB designs like the Williamson that include the OPT within the NFB loop. Therefore, the amount of feedback used plays a significant roll in achieving good stability in a global NFB design. As both versions of the W-3 series clearly show then, when feedback is used in appropriate amounts, it can be a good thing. But when not, the results can be stunningly horrible, which helps to fuel the arguments for or against its use that rage on to this day.
So with the enhancements afforded the new model, how did Heath do in their makeover of the problem child W-3M? Overall, the W-3AM is a huge improvement over its predecessor, making for a very capable amplifier, whereas the previous version was anything but. For those who currently enjoy the performance of their stock W-3AM then, they can do so without the worry or concern for the amplifier itself or the speakers connected to it that the W-3M presented. Improved as the new design is however, there is still opportunity to improve performance further yet for those wanting the best from the W-3 series. Some of the improvement comes from implementing the LF modifications developed for the W-2M. But the rest of it comes from unlocking all the performance capabilities of the most prominent feature of the W-3 series ……..
End Pt. I
End Pt. I
