JayWoodall2
New Member
Lets say I am using a computer as my digital source. And I have a USB cable from computer into a DAC, then into my amp to my speakers. As the signal originates in the computer, it flow through the computer's sound card and on board DAC before it flows out the USB cable. So that once the signal reaches the external DAC via the USB it has already been converted from analog to digital inside the computer, right? So what benefit is the external DAC?
In other words, if you have a DAC "downstream" from a computer that has its own DAC (however bad it may be), then how does the external, downstream DAC provide any benefit? Does it somehow "communicate upstream" to the computer that the computer should not use its own DAC, but to use the external one (of allegedly better quality).
I hope this question makes sense. And I appreciate (in advance) you being gentle with this digital virgin for my "first time", for- yes- I am as ignorant as my question implies. Thanks, JW-
