ADC Cartridge...
Discussion in 'Turntables' started by knockbill, Jan 12, 2018 at 3:22 PM.
  1. knockbill
    knockbill Addicted Member
    6,906
    SE PA
    I got a vintage Dual TT a while ago with an ADC cartridge that has a PSX-10 stylus on it... I have it mounted to a Garrard sled, and just noticed it has a bolt thru it, like a P mount cartridge... Is this a P mount cartridge mounted on a 1/2" adapter? If so, it a good enough cartridge to try on a Technics SL D30, (it has a Technics P28 now)?
    Just trying make use of it, if its worth bothering...
    Thanks...
  2. Vinylmasters
    Vinylmasters Super Member
    1,289
    Saratoga Springs NY
    It's a p-mount, so yes, it's on a universal mount on that weird Dual 'sled' thing'. It's a decent cart, but get the PSX-30 stylus if you can find it (not sure if Gary @ the Voice of Music stills has them or not). EDIT: Gary has 'em: http://www.thevoiceofmusic.com/cata...chType=MfgNameNeedles&MfgName=ADC&Categories=
  3. wualta
    wualta < Spike Milligan, 1961
    6,853
    West Michigan USA
    Azden made these for ADC late in ADC's life. It turns out to be an excellent little cartridge, and original styli are still available for not much money, even today. Definitely worth considering. To confirm that, simply search for ADC PSX here on AK. You'll find many fans of the 30 and 40 styli, which will fit your 10 body because all the PSX bodies are the same electrically.
    Let us know if you have a budget for this project, if you want to make it a project.
  4. knockbill
    6,906
    SE PA
    Thanks for the reply... its on a Garrard sled, I have a couple of SL95Bs and wanted to try it...
    How does it stack up against the Technics P28 cartridge?
    I'll look for the PSX-30, and see what I can learn... thanks for the info...
  5. wualta
    6,853
    West Michigan USA
    The P28/P28ES was the base elliptical from the early lineup of the Technics p-mounts, which are also favorites of mine, but finding genuine replacements for these styli has become very difficult. Aspire to the boron P22 or P22S or P202C, but in the meantime, you'll get very high bang/buck from the PSX-30 stylus (called RPSX-30) in your 10 body.
  6. revox-b77
    revox-b77 AK Subscriber Subscriber
    2,519
    Dryden, NY
    Do as advised, then sit back and enjoy the tunes!
  7. knockbill
    6,906
    SE PA
    Yep,,, the SL-D30 had the original Technics cartridge on it when I got it,, the diamond was broken, and I replaced the stylus with a conical that fit, to try the TT... I never noticed this ADC had the P mount adapter until just now!!! I just mounted it to a spare Garrard sled to try it, as it has the stylus...
    Since the proper replacement is hard to get for the P28,,, I'll look into cost/availability of the right stylus for the ADC,,,
    Thanks again for the info!
  8. wualta
    6,853
    West Michigan USA
    Click on the blue 30 in post #3.
  9. knockbill
    6,906
    SE PA
    Is the EVG stylus a viable replacement, or only the ADC 30 ? Its a little confusing as neither 30 is "blue" on that chart...
  10. revox-b77
    2,519
    Dryden, NY
    You want the original PSX 30 made by ADC. ( the 45.00 one )
  11. SA-708
    SA-708 Appalachian-American
    5,282
    NE Tennessee
    The conical 10s are blue; go for an original ADC RPSX-30 in white.
    When wualta said "blue 30", he meant the colour of the text that was the link to tVoM, not the colour of the stylus.
    wualta likes this.
  12. knockbill
    6,906
    SE PA
    OK,,, thanks for clearing that up!
    The two cartridges are electrically interchangeable, just plug and play( pins wired the same)? Doesn't look like P-mount cartridges need to be aligned? Does the tracking weight need to be adjusted for different cartridges?
    This is the only TT I have that uses them...
  13. revox-b77
    2,519
    Dryden, NY
    No need to adjust anything. Insert cartridge, tighten screw and hit play.
  14. wualta
    6,853
    West Michigan USA
    Exactly. Plug 'n' Play. This is about the only time you'll hear that phrase applied to anything phono, or, heck, analog.
  15. knockbill
    6,906
    SE PA
    Thanks,, I did some googling and found the info,,, not sure I'm up for the "30" stylus just yet... maybe I'll try the ADC as is on the SL-D30 first and see if its much better than whats on it now...
    Other than plugging in the replacement stylus, I really never gave this TT much thought!!! Its automatic, and works fine tho, so maybe a closer look!!!
    I appreciate the info and lessons,
  16. wualta
    6,853
    West Michigan USA
    While I've never heard the 10 conical stylus myself, I do have a 20, which is pretty much a 10 with an elliptical diamond, and it sounds just fine, not obviously a "lesser" cartridge, so if the diamond on your 10 isn't worn, you may find that it will do the job until you can save up for a 30.
  17. boreas
    boreas AK Subscriber Subscriber
    14,789
    Sonoma County, CA
    All the bodies for the PSX-10 through 40 are electrically and physically identical except the PSX-30 and PSX-40 which were gold plated. My "PSX-30" is just what yours would be, a PSX-10 with a 30 stylus. It's a great cartridge.
    P-mounts don't need to (can't) be aligned when used on a P-mount turntable but they need to be aligned when installed using the adapter and installing them on a 1/2" headshell. Similarly P-mount turntables have the tracking force set at the factory at 1.25 grams so, when installing a cartridge on a P-mount turntable, just as with alignment, you don't need to and usually can't set the tracking force. On turntables with 1/2" headshells, you need to set the tracking force at 1.25 grams.
    Now, your SL-D30 is a little different from most P-mount turntables because it does have an adjustable counterweight and anti skate. These are both adjustable to the prescribe P-mount spec. of 1.25 grams +/- 0.25 grams. I'd just set the tracking force and anti skate both at 1.25.
    John
  18. boreas
    14,789
    Sonoma County, CA
    I had an SL-D20, same as the SL-D30 but auto return only. It was quite a decent turntable.
    John
    Note: trying to evauate a cartridge by using it with a used stylus of unknown condition can lead you down a rabbit hole pretty quickly.
  19. knockbill
    6,906
    SE PA
    I did replace the stylus on this TT (P28) not long ago,,, its a conical... I'm not real sure the ADC cartridge would be an upgrade,,, I read some AK posts about the P28, and they pretty much agree that its a pretty good cartridge... I may try an elliptical stylus on the P28 first, if I can find one cheap enough...
    FWIW,, I tried the ADC when I got it, on a 1/2" mount TT,, and didn't like it as much as the Shure or Empires I had been using, it may need a stylus, but seemed to play OK, just not as full sounding, IIRC...
    Yep,, anti skate and tracking are both set at 1.25...
  20. knockbill
    6,906
    SE PA
    I decided to try this ADC on the Technics SL-D30... it sounds very good here, I'm actually surprised how full the music sounds...
    I have a few rookie P-mount revelations/questions,,, I notice the D30 doesn't the tiny nut on the P mount bolt as the 1/2 adapter does, makes swapping cartridges a breeze!!! I like that feature... how do you manage that small nut, if its necessary, small nutdriver? Are other P mount TTs set up with a blind threaded mounting hole also?
    I left the tracking and anti skate both set at 1.25, that's correct I believe...
    The ADC has a stylus cover that swings down to protect the stylus,,, is that supposed to be removed while playing? does it affect the track weight?
    Thanks for info...
