Admiral console
Discussion in 'Tube Audio' started by opossumcrush, Jun 18, 2009.
  1. opossumcrush
    opossumcrush The Central Scrutinizer Subscriber
    1,097
    KCMO
    I got an Admiral console today at the thrift store for free, They were going to throw it away. It was in nice condition when they first got it. They had it priced at $70.00. Nobody bought it, it had been there for about three weeks. Every body kept putting crap on it, and now it's scratched up, but still in decent condition. It is model number Y4941A, with a 9P1 chassis. Is this thing any good? I can't find any info on it.
  2. byoung334
    byoung334 Active Member
    481
    L.A. (Lower Alabama)
    does the amp look like this? THis is one I modded. Low power SE amp maybe 2 watts
  3. opossumcrush
    1,097
    KCMO
    This is it. [​IMG] [​IMG] [​IMG] [​IMG]
  4. DaveWM
    DaveWM Well-Known Member
    559
    hmmm, looks like it might have a hot chassis.
    No separate amp so you are stuck with the tuner/amp package. 50C5 might be good for 1 watt per channel maybe a little more. Not much for such a big console.
  5. bricktop
    bricktop Couch woofer
    3,282
    Central PA
    I've never met Admiral Console, but if he's anything like General Electric, he's probably a good guy...
    Leland47 likes this.
  6. biggguy999
    biggguy999 New Member
    38
    It may not be much power, but with the speakers it came with (OP didn't elaborate as to what- but it looks like 2 tweeters and about a 12" woofer each side), and for the way those consoles were usually used (I'll bet the volume control never got past the 10 o'clock mark ever), it was probably adequate to keep the buyer of this low end unit happy.
  7. gadget73
    32,916
    Southern NJ
    Be careful with it, thats probably a hot chassis amp. Don't go hooking any grounded equipment to it.
  8. AdrianG
    AdrianG New Member
    21
    I have just removed the power amp from a Admiral console Model 8YILC. I thought I would use it as a power amp,. what is this hot Chassis stuff? Does anyone know about the power rating or where I could get info on this? ADRIANG
  9. gadget73
    32,916
    Southern NJ
    hot chassis means that one side of the power cord is probably connected to the chassis as B-. The other side goes through a rectifier to produce the DC plate voltage. Sometimes they don't actually connect the cord to the chassis, but you'd really have to look at the schematic to make sure. The tubes are odd voltages, and they are wired in series, light Christmas lights. No power transformer, so no isolation from the wall really. They are fine in their original box, but can be very dangerous when used outside their original environment. They tend to not like being connected to grounded equipment for example.
    50HC6 tubes I'll guess are probably good for about 2 watts each. I don't have the book in front of me and I can't come up with a datasheet in 30 seconds or less but thats about what most of those type tubes are rated at.
  10. Olorin67
    Olorin67 Active Member
    If it's a hot chassis, don't connect it to other components unless its on an isolation transformer.
    Looks like the unit in the picture also has an Admiral-made record changer. Looks a lot like a VM from the top, but its different mechanically. Some of them have 4-pole motors.
  11. AdrianG
    AdrianG New Member
    21
    Admiral
    anyone have any info on an Admiral 8YILC model? I cannot find anything>? If Ipost a picture can you tell me anything? A
  12. Tom Bavis
    Tom Bavis Audiophool Subscriber
    9,082
    Macedon NY
    Sams folder 631-4 covers it - I may have a copy.
  13. toxcrusadr
    29,062
    Central Missouri
    My FIL up in NE has an Admiral radio/tv/phono console. Keeps it in his garage and listens to it now and then. The TV has nothing but a raster so it needs a complete recap. I've had it on my list for a couple years, never got a round tuit. I think his TT is missing the record multi-stack arm (whatever that thing's called) for some reason. Might even be the same TT. Anyway all this is mere chat, since Admiral consoles don't show up all that often.
