Akai M-8 SEP amps (tracker-x mods)
Discussion in 'Tube Audio' started by BmWr75, Apr 2, 2011.
  1. BmWr75
    BmWr75 Addicted Member
    5,287
    Northeast MS
    Here are some pictures of my new to me Akai M-8 SEP amps. Bought these in a Akai "suitcase" RtR (see unmolested pics here) a few months ago. Read about AKer tracker-x's mods and the cabinets AKer Raul has AKer JohnW make for him.
    A month or so later.....here are the results (see pics).
    I only had one problem after completing the mods. One of the amps had a loud hum and I could only faintly hear the music playing. Ended up it was the amp that has the two piece slide-bar on top that must be pushed to the left to make these amps work as standalone amps. The short piece of the slide bar moves independently and I had not pushed it to the left. As soon as that was remedied, hum problem was solved.
    I'd like to thank:
    1. JohnW for making these white oak cabinets with the ammonia fume finish.
    2. Raul for posting the pictures of his M-8 amps. http://www.audiokarma.org/forums/showthread.php?t=345501
    3. Tracker-x for posting his M-8 amp mods. http://www.audiokarma.org/forums/showpost.php?p=1100906&postcount=9
    An easier to read version of the tracker-x mods is posted here: http://www.audiokarma.org/forums/attachment.php?attachmentid=309141&stc=1&d=1320615983
    I'm still running the stock NEC tubes in all positions and these amps sound sweet. :music:
    Update 1: These amps should probably not be stacked as I've shown them in the pictures. They put out some heat.
    Update 2: List of capacitors purchased for the refurbishment (I ordered a few extra of some of the less expensive.......just in case):
    Tube Depot
    Quantity 9 - Sprague Atom 25 uF 25V
    5 - Sprague Atom 20 uF 500V
    2 - multi-cap cans 20 uF x 20 uF 600V
    6 - Orange Drop .022 uF 600V
    8 - Orange Drop .010 uF 600V
    2 - Orange Drop .0047 uF 600V
    Digikey
    2 - 3.3 uF 350V electrolytic radial
    3 - 1 uF 350V electrolytic radial
    2 - 360 pF 500V mica radial (kind of pea shaped actually)
    2 - 15 pF 500V mica radial
    There is a great possibility I already had some of the required caps lying around which are not reflected in the above orders. They would have been Orange Drops though, probably the .022 uF size.
    Update 3: Added pictures of the bottom of the amps after all the umbilical cords have been stripped out. Pics show the locations of many of the caps there were replaced.
  2. Keessie
    Keessie Super Member
    1,026
    Rotterdam, The Netherlands
    Those amps are really nice.
    Congrats
  3. diamondsouled
    diamondsouled Recycle belly button lint! Subscriber
    8,030
    Canada
    Wow! I wonder if the same can be done with the Roberts version, the 770X and the 770?
    Cheers
    Lar
  4. BmWr75
    5,287
    Northeast MS
    There is a Roberts equivalent to these Akai amps. I do not know the model number.
  5. diamondsouled
    8,030
    Canada
    I believe it is the 770X (first pic). Thing with the 770 (second pic) is the face plate is one piece making it more difficult/involved to make two separates. Not sure if there was a comparable Akai version with an integrated face plate, any one know?
    Cheers
    Lar
  6. 2010 AR D79A
    2010 AR D79A Active Member
    171
  7. JohnMac
    JohnMac AK Subscriber Subscriber
    5,271
    Front Range, Colorado
    I looked but can't find tracker-xs mods. can you help me with a link?
    Thanks,
    John
  8. BmWr75
    5,287
    Northeast MS
  9. JohnMac
    5,271
    Thanks. I looked everywhere but there.
  10. FoolForARadio
    FoolForARadio AK Subscriber Subscriber
    1,108
    Goldsboro NC USA
    Good job! I like the cases. AK'er Sloober and I did these mods on an M-8 and and a Roberts at the same time, he kept the Roberts and I kept the M-8. I've got a hum in one of mine that I need to track down.
  11. BrokenHill
    BrokenHill Well-Known Member
    754
    Newhall Pass CA.
    I came across a pair of the Roberts 770x amps about 15 months ago and did
    the tracker-x mods exactly as described.
    I was very impressed with the results of the mods, so yes the Roberts 770x
    units will respond to the tracker-x Akai M-8 mods, I think the circuits are
    the same or very close.
    I also am using the stock NEC tubes and they sound good in these mono amps.
  12. Raul
    Raul Active Member
    285
    Italy
    BmWr75-
    you are welcome. Great work! Did JohnW made the cases for you or did you built them?
    A question: how much gain/volume have your modded M-8 amps? Mine, with a standard CD player as input, have a rather low volume and I must turn up the knobs at maximum to have a rather good listening volume. I connected these to a pair of Dynaco A-25 that surely aren't the most sensitive speakers around, but I was able to drive them with other small EL84 SE amps, like the ones removed from Magnavox consoles.
  13. Tubeage
    Tubeage Analog Ready
    331
    Connecticut
    Now THAT, my friend, is TOTALLY AWESOME!
    -Alan
  14. diamondsouled
    8,030
    Canada
    Try the Mic inputs, but turn the volume down first :yes:
    Cheers
    Lar
  15. BmWr75
    5,287
    Northeast MS
    Raul,
    I've not tried them with speakers yet, just headphones and there is plenty of gain for headphones.
    Yes, JohnW made the cabinets for me.
    As the prior poster said, the MIC inputs are high gain. Plug your CD player into them and give it a try. Be sure and have the volume turned all the way down on the amps first though.
    Scott
  16. bhamham
    bhamham Super Member
    1,954
    France
    Well done, indeed. Very nice!
  17. jaymanaa
    jaymanaa AK Subscriber Subscriber
    54,483
    OZ
    Some folks do away with that first tube (EF86), but heck, that's my favorite low noise pentode. Also be aware that there is no RIAA equalization on the phono input, so you need to run a phono pre of some sort if you want to play rekkids.
  18. goldear
    goldear Certifiable Audio Junkie
    8,468
    Seattle
    I've never seen a set of those made too look so great before! I absolutely love those cabinets!
  19. diamondsouled
    8,030
    Canada
    The tube you can do away with is the 6AR5 isn't it? Sumpin to do with erase head oscillator?
    +1 on the cabinets, lovely wood work there. I've been thinking that since my Roberts 770 has an integrated face plate that it would be interesting to fabricate a clear poly face plate for each individual amp. You'd be able to see the tubes then. :thmbsp:
  20. BmWr75
    5,287
    Northeast MS
    Yes, the 6AR5 can be removed. I did. Everything is working as it should without it.
    I left the phono tubes in the amps. Will try it with a TT eventually.
    Note: I added the list of replacement caps to the OP.
