These amps have not been recapped
No TrackerX mods have been performed
The amps are all original
Ok, first I cleaned the amps
I added a AC power cords and 1 amp fuses
Here is how I wired Roberts 770x (Akai M8) AC
The right amp already has an AC power cord
Lets walk through the working unit wiring:
Start at the label PLUG. That is the two pronged power cord
One side is neutral and one side is hot
One side (neutral) goes up and connects under that brown heat shield tube to the blue wire from the power switch on/off on the front of the amp
The on/off switch has a green wire on the other end of the switch (blue in, green out)
The green wire runs from the switch to the transformer far end connection marked GND or 0V
This provides on/off control thru the neutral
The other wire from the plug goes to the 117 of the transformer
That's how the amps is to be wired
What I did is wire the LEFT amp for AC like the RIGHT amp
The other amp that does not have a power cord
This amp was the control amp for the tape deck
Look at the image labeled LEFT PT AS BUILT
On this, the main control amp, the AC is also controlled by the tape deck "tape end" switch which shuts down the whole unit when the tape is over. That is a blue wire from the BIG connector plug that connects to the blue wire (under the brown heat shield tube) that goes to the ON/OFF switch on front. This blue BIG connector wire will be replaced by the neutral side of the new power cord.
The green wire from the on/off switch (blue in/green out) ORIGINALLY RUNS from the switch to the 117v OF THE TRANSFORMER
MOVE THE GREEN WIRE (from the switch) FROM THE 117v TO THE 0v TAP OF THE TRANSFORMER.
Attach the HOT side of the new power cord to the 117v of the transformer
Dealing with the big connector on the left amp was easy
I left the AC socket in the LEFT amp so that the RIGHT amp could plug in and both amps could be powered by the LEFT amp on/off
I also preserved the connection to keep the STEREOPHONES operational.
Slapped a couple of cases together and there it is, instant cool, Single-Ended Pentode mono block stereo
