Ok she just under 2 feet in length thus far with a 4 and 1/4" beam.As for assembly sequence,if you look at the first post you will see the keel piece and bulkheads that you start with.You soak the planks in water for a few hours then bend them around a can of stain and clamp it in place.Allow it to dry and then remove the clamp.The plank will retain The bend and you can Then drill pilot holes and use a needle nose pliers to push the nails into place to affix the planks In place.You continue plank by plank until the hull is covered.Since I elected to single plank the hull I had to fill gaps and cracks in several places with automotive spot putty.I sanded it down with 100 grit followed by 220 grit.Then I airbrushed primer followed by several coats of white.I used a liner brush to paint the black,yellow ,tan and dark brown.Follow up questions welcomed.
