Mellotronix
Super Member
I have already covered my phono preamp fails in other threads, so I won't bore you with the details, but I did order a new Sutherland, which should get here on Friday, In the meantime, I plugged my VPI Prime Scout directly into the MM pre on my Yamaha AS801 integrated amp with surprisingly good results, considering that the Grado Statement cartridge only outputs about 1.0mV. But having the volume up so high on the Yammy could be dangerous should someone switch sources without adjusting the volume.
I decided to try an using an old Focusrite USB computer audio interface as a step-up preamp. Basically, I'm running the turntable audio directly through the Scarlett 2i4. The USB's only purpose is to power the unit.
Turntable output--->Front of Scarlett (inputs 1 and 2 using RCA-¼" adaptors)
Scarlett Balanced Outputs 1 and 2--->Yamaha AS 801 MM phono input (again using RCA -¼" adaptors)
Gain staging: The potential for a distorted, noisy mess exists here so it pays to work with the gain staging to get the best signal with the least amount of distortion and lowest possible noise. I have the Scarlett Inputs set to Instrument and the gain is exactly halfway. Pads are off. The Direct Monitor knob is set fully to "Input." The Monitor pot is up ¾.
After much knob twisting and button pushing, I found the above to give me a nice, punchy signal with no audible distortion and very low noise at regular listening levels. I've almost given away this old Scarlett several times, but I keep finding uses for it.
