analog addict
Glory or Death!
Well it's time. I finally have everything to a point where I'm happy, and I can let 'er rip. My wife was complaining tonight when I cranked up the J.S. Bach Toccata and Fugue in D Minor and all the panes of glass in the kitchen cabinets started to shake.
Right main channel:
Simplex W VOTT loaded with two 1953 vintage 515s. These served daily duty in a 750 seat theatre in Scottsbluff NE until 2003 or so. Next up in the stack is a M19, added to stretch the upper and lower end. On top of that is a 1005b tar filled multi cell with a 288b large format driver. On top of that is an array of Frazier horn tweeters crossed over at about 10KHz to add some sparkle.
Right Fill channel: 828 cabinet loaded with a 604-8G
Center: 210 VOTT loaded with a pair of the 515s. 1005b/288b up top.
Subwoofer(s): Stacked JBL 4685s each loaded with a pair of JBL 2225Hs
Left Fill Channel: Identical to the right
Left Main Channel: Identical to the right.
Electronics: (From the top down)
modded VPI HW19 Mk II TT with a Rega RB-250 arm and Denon DL-110.
Applied Research and Technology (ART) 311 Active crossover running the subs only. A gracious gift from Tom Brennan...:thmbsp:
Restored McIntosh MX-110z loaded with Telefunken red tipped ECC83s pulled from medical EEG amplifiers.
Freshly built Dennis Had approved 6SL7/6L6 SE amp good for 5-6 WPC. Currently loaded with 1950's RCA 6SL7s and Tung Sol 5881s and set up to run 16 ohm loads.
Pioneer Elite F-51 Tuner and DV-C36 DVD/CDP
Restored SC ASC-433 amp loaded with GE 7189As running the center channel. Split mono input from the center out of the Mc 110z using one channel for the 1005b and one channel for the 210. Separate discrete crossovers for the 1005b and 210.
Niles SVL-4 speaker selector box with gain control for each speaker set. Running both set of mains (and others if I feel like adding them)
Restored Hafler DH-500 running the subwoofers, mono signal, one channel per box.
There's other stuff that subs in and out, but that's what's running at the moment, and I couldn't be happier...until tomorrow or the day after....:scratch2:....
Right main channel:
