EJB14
Hi all;
Hoping that someone has seen this before and can tell me what to check out.
NAD 1700 Preamp; has two sets of preamp outputs - "Normal" and "High" - The first pic is of the problem using a1Khz signal as an input to the CD inputs - notice the small dip at the downturn of the positive peaks? This only occurs using the 'Normal' output. The "High" Outputs produce a nice sine wave that matches the wave I play into the input. The Tape Out's produce the same nice wave. The preamp sounds great though headphones (which makes sense since the headphones are attached to the high output).
The RightMark Audio Test software is reporting significant distortion on the normal outputs (> 3%) while reporting a much more acceptable 0.02% on the high outputs.
Just replaced all the capacitors in the preamp section with Nichicon FG's hoping that was the problem. Given the high outputs are operating per spec, I am wondering if the outputs are amplified separately or if there is something in line with the normal output only that is not operating per spec.
Thanks!
-Ed
"Normal" Pre-amp output wave:
"High" Pre-amp output wave:
Thanks!
-Ed
