Hi,
I have a list to help for your recap,
For the most of the small capacitors, i used Elna Cerafine and Silmic II exept for the driver board C815 & C817, they are too big to fit, i used Nichicon there, and Nichicon for the bigs too.
Main Alim
4700uf 63V
4700uf 63V
4700uf 63V
4700uf 63V
1000uf 80V
F-2029 - Driver board 1
C801 2.2uf 50V Low noise
C807 220uf 6.3V
C815 47uf 80V
C817 47uf 80V
???? 3.3uf Radial
???? 3.3uf Radial
F-2029 - Driver board 2
C807 220uf 6.3V
C815 47uf 80V
C817 47uf 80V
???? 3.3uf Radial
???? 3.3uf Radial
F-2030 - Power Supply
C052 100uf 75V
C054 220uf 75V
C055 100uf 75V
C057 470uf 16V
C058 220uf 75V
C060 220uf 50V
C062 220uf 50V
C901 47uf 10V (*BP*)
C902 74uf 10V (*BP*)
C906 1000uf 6.3V
C907 100uf 50V
C908 1uf 50V (*BP*)
F-2019
C701 0.47uf 25V
C702 0.47uf 25V
C703 47uf 16V
C704 47uf 16V
C705 47uf 6.3V
C706 47uf 6.3V
C709 4.7uf 50V Low Noise
C710 4.7uf 50V Low Noise
C717 2.2uf 50V Low Noise
C718 2.2uf 50V Low Noise
C719 47uf 6.3V
C720 47uf 6.3V
C723 4.7uf 50V Low Noise
C724 4.7uf 50V Low Noise
C731 47uf 50V Low Noise
C732 47uf 50V Low Noise
C733 220uf 35V
C734 220uf 35V
C799 220uf 25V
F-2006
C601 1uf 50V Low Noise
C602 1uf 50V Low Noise
C603 10uf 10V
C604 10uf 10V
C607 47uf 6.3V
C608 47uf 6.3V
C613 47uf 6.3V
C614 47uf 6.3V
C615 4.7uf 50V
C616 4.7uf 50V
C617 3.3uf 50V Low Noise
C618 3.3uf 50V Low Noise
I don't remember if the manual or schematics was wrong somewhere.
Originally, they was 100% build with Elna
I think you can use Cerafine as a better substitute.
http://www.partsconnexion.com/capacitor_ele_elna_roa.html
Will do so.I don't know, if they are good, leave them alone.
Ohhh, that sounds a tad difficult !Don't reference the manual for your capacitor list, Sansui service manual accuracy has never been good.
Make your list from what's in the amplifier. It doesnt take very long, and you won't have to be confused.....
I've never used a SM to make a cap list...
Any suggestions?Ohhh, that sounds a tad difficult !
No wonder that I saw another list on the forum which has some difference of voltage on F-2019, listing 4 caps of 47uf 10V, instead of 4 caps of 47uf 6.3 V !:scratch2:
It also omits 2 caps on same board , 47uf 50 V.....
Any suggestions on using silver-oil caps? or they are a no-no....
Dev
I'd use 105C Panasonic FCs in most power places, taking care to match the pin spacing. "Audio" caps won't buy you anything (others will disagree and that's OK too). I would not change the orange low leakage Elnas on the tone board at all, unless there's something wrong with them, but absolutely change the two white Elna input caps (tantalum) near the edge. Use 0.47 uF film caps, Panasonic or similar. Do not use physically large caps there, which rules out all audiophile films. It's a high impedance location. Noisy transistors are also a possibility. I just did one of these and IMO, it may be one of the best sounding amplifiers that's ever gone across my bench. Absolutely magic when working right. You'll probably have to do a couple applications of DeOxit on the tone and other controls- look at the response with a scope to be sure they're working right. Where are you- put at least some vague description in your profile!
So no concerns on polarity then when using those non polarized films?
