See pic. Is that possibly bad inductior? Having issues with low output from mid and hi. Close up is one in question. Other pic is good one. Also what are options for replacment? It is L2 on schematic for Jbl 4435. 1.0mH
They impede the flow of high frequencies. They rarely go bad in my experience. BTW Script, you zeroed in too close on the schematic to show what it's really doing.What do inductors do exactly? Some of the ceramic resistors on network look like they have endured moisture or overheating. Discoloration and flaking of ceramic material.
Or... the insulation could be melted causing shorts within the windings, bringing the effective number of turns down and lowering the value.I would suggest that someone was biamping it and put a lot of power to the woofers for a while. The 18mH inductor appears to stay in the circuit even in bi-amp mode and I would think this to be the burned inductor.
If you put an ohm meter across it (with at least one leg out of the circuit), the resistance should be so low as to almost read as a short circuit. If the meter reads infinity, the coil is burnt open.
