1. Rest in Peace Paul (Kegger) If you would like to help the family in this time of great sorrow and need, you may donate on their GoFundme page: https://www.gofundme.com/mckechnie-medical-and-funeral-fund?
    Dismiss Notice
Behold the Baltic 50 made in Latvia...
Discussion in 'Speakers' started by kfa888, Mar 17, 2011.
  1. kfa888
    kfa888 Addicted Member
    7,657
    Vancouver WA
    I saw these on CL for 30 clams. WTH are they? Dome tweet three way. Search that there interwebs and find nearly nothing expect our man thedelilas, and he had Baltic 30's (small 2 ways) has said had great build quality and sound. Also ready there were very nice drivers under these cheap looking trim rings. Drive through rush hour traffic and check them out. Hum smaller than i thought. Cones and surrounds look very quality as does the tweeter. interesting. Heavy, nice looking drivers, slot port on upper back, nice looking port trim and connector plate with attenuators. He said he had nothing to hook them up to but would take them back if not 100% functional. Some cab water swelling issues but all the drivers look new. Cheap gamble, I'm in. WOW I'm glad I took the chance. I hooked them up and liked them very much instantly. Refined deep bass (says 30-20000), tight and quick sounding. Nice and balanced but notice they were a little off and veiled sounding on the top end. Driver check and crap one unobtainable tweeter is working but quiet. Checked the L-pad, seems fine, traced the wires, tested good. Pulled the tweet has continuity, Tried another known good tweet and it was quiet too. So I think it is a bad cap or something wiring related. Tweet tests fine. Dodged a bullet there. I'm pretty stoked about these. Very rare as far as i can tell, super nice drivers, great sound just setup quick on a crap amp. these are going to be nice. Medium efficient and like a little throttle.
    Very unassuming looking...
    Almost looks like cheap component stuff until you pop the hood and WOW...
    Heavy bass driver
    Mid in a purpose built chamber...
    the stuffing in the mid chamber is contained in a hair net looking thing. Look at that driver.
    - BTW none of the drivers have any markings at all.
    Nicely built little tweet...
    I am amazed at the cast mid chamber, jack plate, trim panels, choke reels, the tight routing of the driver recesses, twisted wires, screw inserts, etc the whole speaker shouts quality. Reminds me of KEF, B&W, Celestion type speakers.
    OX is has a thoughtful and clean layout
    L-Pads...
    BTW I am sure this is the first time these have been apart and look new inside.
    Thoughts?
  2. thedelihaus
    thedelihaus Nocturnal transmissions Subscriber
    29,612
    Boston Area, Massachusetts
    Great grab, Kelly!
    My buddy and AKer HepcatWilly now has my two pair of Baltic 30s. Tweets can sound a bit "hot" on most SS, he runs his on tubes and it's a big, meaty, accurate sound, with the tubes smoothing out the top just the right amount.
    The only markings on the drivers are the small stamped initials/symbol on the cones. But like I said, quality build to them.
    Keep us posted on progress!
  3. Sir.Byrd
    Sir.Byrd Lunatic Member
    15,548
    Seattle, WA
    Cool, and plywood too!
  4. Quadrant4
    Quadrant4 New Member
    45
    Columbia, TN
    Heres a site that sells a "Baltic" line of speakers with a Baltic 90 model thats a three way like your 50. Hasn't been updated since 96 though. Maybe theres a chance the email still works. Worth a shot.
    http://www.eliteweb.com/baltlines/index.html
  5. Tom Brennan
    Tom Brennan AK Member
    14,884
    Here and there
    I had some Lithuanian speakers that were stuffed with kugelis, zeppelins and rye bread.
  6. audiozaz
    audiozaz rtfm!? - tl;dr
    3,422
    Eastern Townships, Qu├ębec
    Unassuming looking at first view, but it's a good thing you poped'em open to let us see the build quality!
    I can spy plywood, not particle board. Real wood veneer, on all sides? :) Nice!
    Crossover seems to use good capacitors that won't age badly like electros. Drivers seem to have a nice build as well.
    Enjoy!
    az
  7. MunkeyQ
    MunkeyQ Super Member
    2,142
    South-East England
    Would not expect that sort of build quality from looking at the trim rings! Very nice find, and those seem like some very well made drivers.
    The capacitor look like Russian paper-in-oil ones, which are very highly prized in the audio circles for their sound and longevity.
  8. kfa888
    7,657
    Vancouver WA
    I'm glad i did some research and found out under the plastic trim rings are heavy cast drivers or I might have passed. Kinda the opposite of what you usually see, crappy stamped drivers under Aluminum trim rings. I gave them a long listen in way less than idea setup and am amazed by the sound despite the low output tweeter. I need to sort that out. I'm 90% sure it is not the tweeter itself.
    There does seem an oily substance has leaked from the green cap standing on end in the middle of the OX, wonder if thats the issue. I don't know enough about XO's
  9. MunkeyQ
    2,142
    South-East England
    Could you post a pic of the capacitors, side on? Pretty sure the two rectangular cans paper in oil, which means they'll still be good in a hundred years or so...providing they don't leak! I personally have never seen "ordinary" looking bookshelf speakers like that with oil caps...they're normally reserved for exotic Altec horns and the like! Hold onto those speakers!
    The little leaky one looks like a nonpolarised electrolytic...very good chance that's part of the tweeter's filter given its physical size. It may have a low enough capacitance that the crossover point is now much higher than it should be, accounting for the reduced output.
    Otherwise, it's a good idea to check the solder joints and clean/bypass the L-pads just to be sure. Posting a rough scribbled schematic would help too. :thmbsp:
  10. voltcontrol
    voltcontrol Fizheuer Zieheuer
    5,985
    Waalwijk, The Netherlands
    A wolf in sheep's clothes! Cool . :)
  11. dc270
    dc270 Now Off The Reservation..... Subscriber
    12,668
    North Texas
    Did very good there Kelly!! Get the problems sorted out and you'll have some keepers I think!!
    DC
  12. kfa888
    7,657
    Vancouver WA
    Yep, these speakers look cheap on first glance but are some of the best built speakers i have seen. Even the way the drivers fit in the perfectly routed holes, the attention to details etc. Amazing. Yeah, these are going no where, I already love the sound from them and can hardly wait to get that tweeter 100% tweeting.
    I did all that to no avail. I bet it is a cap near the end.
    I think these are made in the late 70's early 80's from info I can find.
  13. bakes
    bakes Super Member
    1,328
    latham, NY
    Very cool - I would have found those irresistable. My guess is that the leaky NPE cap is the source of your tweeter worries. Measure the other and order something similar - maybe a Solen - for each of them as if one goes, the other might not be far behind.
    Again, very, very cool!
  14. coonmanx
    coonmanx Super Member
    2,202
    Colorado Springs
    Did you try to contact Baltlines Audio yet to see if they are still around?
  15. kfa888
    7,657
    Vancouver WA
    No, for what? Schematic? I think the tweet is fine. Tested good. replacement sounds the same (low output)
  16. kfa888
    7,657
    Vancouver WA
    Been listening some this morning while I work from home, man the bass is fast deep and effortless on these. Great sounding speakers. Got to sort that tweet ASAP.
  17. frperdurabo
    frperdurabo AK Member Subscriber
    1,786
    Hawthorne, New Jersey
    I think these were made in the 90s; post USSR break-up. I just pinged my Latvian friend over to this thread; hopefully he'll sign-up and join in.
    The old Soviet Union made some pretty interesting cameras - mainly Leica, Contax copies...so I've always wondered if there was a factory in Siberia turning out perfect copies of say, the Altec 604. Does anyone know?
  18. marcusekner
    marcusekner Racer
    355
    Sweden
    Not that the're an ex-USSR country, I think, but Bulgaria turns out some pretty nice speaker drivers aswell. There's a speaker store here in Sweden who have been selling the Bulgarian speakers for ages, and they have quite a reputation. They're really ambitious, making midrange drivers with AlNiCo magnets and very nice horn loaded ribbon tweeters. And I shoot most of my pictures with an old Leica copy with a Zeiss copy-lens. Excellent camera.
    These speakers look really well designed. They even used proper PIO capacitors. I'm impressed.
  19. mashaffer
    mashaffer Super Member
    3,193
    North Central Indiana
    Those are neat. My first thought was that the tweeter looked a little suspect (hard dome?). Glad that they sound good. I like the solid look to them.
    mike
  20. barredowl
    barredowl Before and after Science
    2,929
    Ypsilanti, Michigan
    Those aren't trim rings Munkey but the edge of cast woofer and mid frames if you look closely you can almost always tell the difference between machined solid metal and hollow plastic or stamped trim rings. Those look like nice build quality, good pick up!
