musichal
poet emeritus
What components comprised the best-sounding system you ever heard?
What were those in the most expensive you heard?
Were they the same system?
Do, or did, you own it?
Many of you, I expect may find these questions difficult to answer, regardless of the brands and expense involved, at any level. Sme have had more access to more gear than others.
For me, I have some difficulty myself. Although I had the opportunity to hear some fine systems, my access was not nearly as wide-ranging brand-wise as many of you. And my access to premium gear was mostly twenty-plus years ago.
That makes my answer a bit easier. The best I heard included a brand-new Audio Research SP-11 preamp with dual ARC M-300 power amps and a Well-Tempered Turntable with a Denon DL-301 cartridge. However, the speaker choice is murky for me because I heard the very same components - the very same specimens - via two different pair of speakers in two different rooms. The Duntech Sovereigns should have sounded best, but weren't placed well in their room. In a different room, with better placement, a new pair of Klipschorns sounded better to me (and to some others present also).
Khorns were about four grand a pair at the time, while the Duntechs were $30,000/pair. Wish I'd been able to hear them properly placed, but I must go with what I heard. In this case, the most expensive was not the best-sounding to me. The Duntechs, weighing in at almost 300 lbs each, IIRC, well, we were not allowed to move them, and were set upon a small stage near one corner of a large room. Nor was I allowed to make any music selections. So it was not a level playing field, at all. Whether or not the M-300 was a good choice for the Sovereigns is a factor unknown to me, as well, but bad placement made that a moot point, anyway.
I never owned any of this, except finally a pair of (older) Khorns, which did not work well for me, as some of you may recall from other posts.
What about you?
What about you?
