BSR XL- 1200 Linear Turntable
Discussion in 'Turntables' started by jayzjayz, Oct 14, 2006.
  1. jayzjayz
    jayzjayz New Member
    25
    Philadelphia, Pa.
    A few years ago I purchased BSR XL-1200 Linear Tracking Turntable. It was working fine at that time. I packed it away along with some other old stereo equipment,also in good working condition. Now to my problem?
    The turntable turns on and both speeds work but when you hit the play button the arm does not work and does not track at all.
    Does anyone know what this problem could be. Can this problem be fixed by me or do I need to get it repaired professionally.
    I would be grateful for any ideas or help.
    Jayz
    my email jayzjayz@verizon.net
  2. Nat
    Nat AK Subscriber Subscriber
    11,937
    Old thread, but was looking at this exact table found at the dump in its box with manual. This is a pretty low end linear arm table, so probably not worth spending money on, but it seems pretty simple to repair, or at least to check out.
    First, look at the bottom (either hold it above you, or remove the platter and turn it over) and see if you put the transit screws in before you put it away -- that might be the problem. They are usually red painted, and the two that lock the arm mechanism are in the back left hand side. If they are there, take them out.
    If that doesn't solve it, with the platter off and the stylus removed, unscrew the screw near the spindle with the electric bolt sticker pointing at it. Pop out the section of plastic that the screw holds down, and use the fast forward button to position the arm over that gap. Unplug the table so that the arm stays there.
    Flip the table on it's dustcover (rest it on a piece of cloth), and remove the feet and the screws around the periphery of the metal plate and remove it. Now remove the screws at the back of the remaining plastic bottom plate, and lift it out carefully, making sure you don't whack the arm against the plinth. The arm mechanism is on the plastic bottom plate and you'll have to maneuver a little to get it to flip over so you can look at it.
    There are two potential easy to fix problems - the grease on the slides may have dried up (not a problem on mine, so probably not on yours either) or the belt that drives the arm mechanism may be loose or broken. There is a motor on the plate that drives a chopper (a disc with slots in it for a photodiode and detector to sense motion) which in turn drives the arm motion. If that belt is loose or broken, it needs to be replaced. To do that you have to take the chopper/worm screw out of its pivots, but it appears to be held in them simply by the tension of the belt. And if its fallen out, that suggests the belt is broken or loose.
    You can also see a cam on the arm carriage that obviously adjusts how much deflection the arm has before it moves, but I wouldn't touch that.
    Hope this helps someone.
  3. Sam Cogley
    30,827
    SW Missouri
    A BSR linear tracker? Considering some of the BSR tables I've seen, this seems like a potentially bad idea...
  4. Nat
    11,937
    Well, I wouldn't recommend anyone run out and get one, but if you have one or are curious how they work (or how it was possible to make them so cheaply), its an easy one to get apart. Sometimes the appeal of things is working on them, not using them -- and this is a lot cheaper than a boat.
  5. wilkes85
    wilkes85 Super Member
    1,241
    Central Saskatchewan
    a linear tracking BSR? hm... I want one lol, as a novelty if anything.
    It would probabally be the only BSR turntable that ever tracked properly.
  6. Sansui Louie
    Sansui Louie Curmudgeon
    4,836
    It would seem to me that if BSR had a linear tracker, it would have been in the mid to late 80's, and it was probably badged BSR and made by someone else. I wouldn't expect it to be a great performer but I am darn curious as to what it is. Pics?
  7. Sam Cogley
    30,827
    SW Missouri
    I'm not so sure about that...LTs have a reputation (possibly undeserved) for not living up to their concept. A BSR seems like a good way of really screwing up the tracking.
    That said, my parents have owned a ceramic-cartridge BSR cheapie since the early 70s (if not earlier). It's always done its thing without issue. Certainly not an audiophile piece, but it doesn't eat records alive either.
