I recently had the good fortune of finding a very nice Yamaha CA-610 in the attic of a house I bought four years ago. Should have cleaned out the attic sooner. At any rate, it sounds great, very clean, but the lights for the output panel meters were burned out. I did a quick conversion to blue LED's, using only the LED's and two 560 ohm 1/4 watt resistors (stuff that most people have around the house).
Also, the vinyl covering on the wood was shrunk and bubbled in places, so I gently peeled it off, and gave the wooden case a light sand and a coat of Minwax polyurethane varnish. Looks great.
Below are pics of the wiring diagram and the final result. Simply clip out the two dead bulbs. Replace one with a 560 ohm resistor. Replace the other with the two LEDs and the resistor, wired in series with the proper polarity. Current through each should be about 17mA, under the LED's rated 20mA. Be sure to properly shrink wrap and/or tape everything so as not to short against the faceplate.
A nice touch, the standard 5mm LED fits right into the original green silicone rubber grommets.
