Hope this helps ...
I posted this on another forum after I figured it out .....
Cut the end off a USB cable , stripped the sheath off ....
The green and white are data , the red and black are power , black being ground.
Spliced the usb power wires to a mono 3.5mm jack cable and presto , 851 now has a 12v trigger out !! Snip the green/white wires , wrap rest with electrical tape or whatever to make pretty ...
Turns the amp on and off !
It would probably work with anything , TV’s etc , that has a powered USB port ....
Bk
Just in case anyone else is interested...
Personally , I think this is a potentially great problem solver for some ...
I know it was for me ...
I figured it out after I found this , knowing a USB port had power ..
