s-petersen
Scott
I purchased this HV power supply which is good for up to 550v and 500 ma, it is an electropheresis power supply, it has a safety feature built in that will not allow the supply to have power at the leads without a load, in case the leads are disconnected and left hanging. I would like to eliminate this feature, as the supply drops out with less than ~5ma and will not turn on with any voltage on the output. The supply was damaged in shipping, and IC 8 was squashed out of the socket. I was able to straighten the pins and reinsert the IC.
The supply seems to be a switching supply, without any computer control or major logic.The 4 rectifier diodes are mounted directly to the transformer,from there it goes through the large choke to the smoothing board and back to the main board outputs.
