onanysunday
Listen carefully
Hello,
I just recapped an Akai AM-73 Reference Master Integrated amp. Before the recap, it had issues with audio occasionally dropping out on one of the channels that could (temporarily) be fixed by repositioning or jiggling one of the dials on the front. So, when I was in there doing the recap, I also cleaned all those switches on the front panel with deoxit. This did seem to help a little, but the audio still drops out on occasion but not as much as it used to. I am always able to get it back by jiggling that same switch a little. I am wondering if this issue may be caused by a dirty or worn out switch in ADDITION to failing relays.
I am wondering whether replacing the two relays could resolve any remaining issues. I should mention the relays always "click on" 100% of the time on start-up AND the audio is still ALWAYS restored by repositioning the same, one switch- so it is very likely that the switch is 100% the culprit unless the relays are somehow tied into those switches where adjusting them also impacts (or effects) the relays as well. The relays are still available for purchase while the switches are not. I'm aware it may be a lost cause, but wanted to mention it to see if anyone with more experience on these matters could chime in. I will purchase and solder in those relays if it could help my issue. Thank you.
