Carpet for dampening subwoofer vibrations?
Discussion in 'Speakers' started by ultumax, Jan 23, 2019.
  1. ultumax
    ultumax Super Member
    1,170
    Canton, OH
    The subwoofer shakes the floor sometimes.
    I was wondering if you could put carpet or something under it or around it to stop it from rattle the whole upstairs? Shakes the windows also . But I never put it over half volume due to smaller room size .
    Anyone tried this or have pics ? I cannot afford or fit bass traps in my room right now.
  2. F1nut
    F1nut Super Member
    1,968
    The Mars Hotel
  3. Grenadeslio
    Grenadeslio Super Member
    3,695
    dampening subwoofer
    Why would you want to get your subwoofer wet lol?
    darkblue94 and classic carl like this.
  4. bowtie427ss
    bowtie427ss arigato gozaimashita
    17,365
    Land of Milk & Honey Boo Boo
    That damn damp damping dampens my spirits.
    classic carl likes this.
  5. swechsler
    swechsler Frog Whisperer
    5,422
    7th row center
    I read an article a while ago where the writer used a bicycle inner tube (inflated, of course) under his subwoofer to accomplish the same thing.
  6. classic carl
    classic carl Without Music, Life Would B FLAT. Subscriber
    6,210
    North Coast of Pa.
    I would think that would allow the sub to move all over the place. Inflated bike tubes are still very soft and squishy. I don't use anything but the room carpet and pad under my subs, but I have used Auralex products before. I presently use their monitor style isolation pads under the center channel speaker for my HT. It sits on top of one of my 2 channel system subs. The sub and the center speaker are never on at the same time because they are connected to 2 separate systems..
  7. homebrew
    homebrew Active Member
    263
  8. donprice
    donprice Wound up workin' at a gas station.... Subscriber
    2,563
    I suspect the windows (and other stuff?) are rattling due to being loose. Isolating the sub from the floor may not help. Try stuffing a wedge (paper?) between the window and frame and see if it helps.
    Hint - wait until everyone else is gone...crank up the sub to stupid+1...then go hunt the rattles and see if you can fix them...move them...throw them out...whatever.
    Turning down the sub is the last resort ;)
  9. darkblue94
    darkblue94 It wasn't me. Subscriber
    9,060
    The Pacific Northwest
    I'm pretty sure that the sub is already cranked up past 'stupid +1.'
    RTally and classic carl like this.
  10. ultumax
    1,170
    Canton, OH
    One pane of two pain window is broken but my dad still hasn’t replaced it.
    It’s a diy sub it’s on a riser not spikes .
    Tho I don’t hear this window rattling as much a the one beside my subwoofer. It’s even shook the downstairs lights and my closet door wich I opened to stop the noise.
  11. Lou F Quincy
    Lou F Quincy New Member
    14
    Pacific Northwest
    "The subwoofer shakes the floor sometimes."
    Spikes are the cheapest and easiest remedy I can think of besides, well, turning it down. SCIENCE !
  12. ultumax
    1,170
    Canton, OH
    Ahh I see do hardware store sell spikes? Carpet underneath padding I have too it could help ? On. A low budget til I find a job so cheaper options would be nice .
    Stereo integrity si ht 15” it’s powerful for the lower wattage it is.
    I’m saddened it’s discontinued
  13. JimPA
    JimPA Distinguished Member
    3,229
    Grover's Corner PA.
    My subwoofers shake my entire house.
    TudorTurtle likes this.
  14. ultumax
    1,170
    Canton, OH
    FA136BD1-AD6C-4564-98C4-123A640E721B.jpeg 7DC3480C-FE5D-40DB-A3B3-1F1E2AB3EE03.jpeg This stuff and current riser
    Didn’t wanna throw it away so figured I’d use it to stop bass vibrations.
  15. ultumax
    1,170
    Canton, OH
    Any ideas ? Could I put the sub on top or place carpeting around it to stop vibrating of the whole upstairs?
  16. musichal
    11,811
    Norman OK
    You've already been provided the two best low-cost ideas:
    spikes
    turn it down
    You can easily improvise your own spikes virtually free by using four nails or wood screws, some wood or MDF scraps and a small bit of ingenuity. Figure it out and try it out.
    darkblue94 likes this.
  17. DavidF
    DavidF Active Member
    351
    San Jose, CA
    Not sure I get the problem. You have the sub energized to get a LOT of bass in the room but you want to damp down that same bass? Turn it down, perhaps?
    Unless you have some wicked room resonances building up that are peaking way above the average response. You can't treat those with any small of amount of padding or damping material. Best bet is to try to determine what you are dealing with in terms of resonance and try moving the sub around in different locations. You won't necessarily remedy the sub resonances but maybe the rooms interaction with same.
  18. ultumax
    1,170
    Canton, OH
    Yeah poor room acoustics, turning it down made the bass more accurate.
    If subs on a riser does the riser need spikes?
    It separates it from floors.
    It’s such a loud sub vs room size turning it down doesn’t effect spl much .
  19. ultumax
    1,170
    Canton, OH
    The riser might be the best for now should I take the sub off of it and post pics to see if riser needs spikes on bottom? It rattles the ceiling / walls more then the floor. Bass waves just too big to dampen probably.
  20. ultumax
    1,170
    Canton, OH
    Any more ideas or just buy lots of spikes and out em on bottom of riser?
