Cerwin-Vega D-Series Spec sheet
Discussion in 'Speakers' started by Chris Brown, Feb 9, 2007.
  1. Chris Brown
    Chris Brown AK Subscriber Subscriber
    2,599
    Northern California
    When I purchased one of the pairs of Cerwin Vega D-9’s I had, the owner had kept everything from the receipt to the sales information that came with it.
    I found this again the other day and figured I’d scan it. I don’t know if this information is listed elsewhere or not, but I figured some might find it useful:
    This has information for the D-1, D-2, D-3, D-5, D-7, and D-9
    Edit: My original scan was lost when I moved from Comcast Residential to Comcast Business and they erased everything I had hosted on the free webspace they gave me... but it is identical to this image.
  2. crwtb
    crwtb New Member
    5
    thanks alot,chris
  3. 6thumbs
    6thumbs AK Member
    1,435
    Midwest
    thanks chris always wondered about my d-3s
  4. EricV
    EricV Active Member
    139
    Clearwater, Fl
    As long as...1970's HED?
    I realized this may be considered hijacking the thread, so I dumped it from here and will start a fresh thread.
    Sorry!
    EricV
  5. sloppy
    sloppy Active Member
    174
    Why does the D-7 have a lower frequency response than the D-9s? I would have thought bigger would equal lower. Is the difference between 25 and 29 even audible to the (average) human ear?
  6. sorenj07
    sorenj07 Super Member
    1,180
    Boston, MA
    Thanks a bunch, I just got a pair of D-7's and it's nice to have some specific information about them.
  7. E_man
    E_man New Member
    1
    Specs for D-5's
    Hi,
    Does anyone still have the specs available for the D series ? This string previously had it, but it seems to have disappeared. Given that I just picked up a an old set of functioning of D-5's and refoamed the woofers, I am now curious about their frequency response and power handling. Any available info is greatly appreciated.
    Thx.
    E.
  8. sloppy
    174
    From da grave! My 3 year old question still stand, though :D
  9. Blast
    Blast I Wanna Rock Subscriber
    2,656
    Kansas City area
    I wonder if what was originally posted was this:
  10. argent81
    argent81 New Member
    1
    i want to buy a couple of cv d6 but i cant find info.... someone can help me?
  11. Bstable
    Bstable Super Member
    4,102
    Fredericksburg Va.
    I have 2 of those. I also saved everything that came with my D-3s. The woofer surrounds are starting to go so I have not listened to them lately. I have lots of spare midranges and horns for these, but can't seem to find non- foam rotted woofers.
  12. HarryB
    HarryB Active Member
    425
    New Albany MS
    My D9s have 4-8 ohms on the crossover. I think these speakers are closer to 4 ohm. What is the Ohm impedance for the D9s? I know my receiver gets a lot warmer when I drive the speakers full tilt as opposed to my Altec 9s. I do know these can get STUPID LOUD.
    Thanks,
    Harry
  13. sloppy
    174
    Why replace the woofers? Just redo the foam.
  14. Bstable
    4,102
    Fredericksburg Va.
    That is what I am going to do. I was trying to find a pair of CVs that had good woofers at a GW or SA for not much coin. That just isn't happening. My brother found a pair of CV D-3s and bought them for me, but the woofer foam was gone. That is why I have extra X-overs, tweets, and mids.
    My D-3s are in excellent condition, so it IS worth trying a refoam.
  15. Crankit
    Crankit New Member
    18
    Nipomo, California
    Harry,
    What size fuse do we need in our D-9's. I just purchased a pair and blew a fuse on fairly low volume? At one end of the fuse I removed was SOCSD4 and the other end is D250V2A. I'm assuming it's 250 volts at 2 amps and probably not the correct one... Thanks
  16. HarryB
    425
    New Albany MS
    The fuse I pulled out is a Buss MTH4 250 volt.
    Hope this helped,
    Harry
  17. HarryB
    425
    New Albany MS
    You may want to check the DC offset on your receiver/amp. If it is more than a few mv you may have problems with your amp. The speaker protect should have engaged and shut off all sound. if it failed to trip your speakers could get direct voltage and blow fuses and or speakers. You do not want to see the "magic smoke".
    Harry
  18. jocko_nc
    jocko_nc AK Subscriber Subscriber
    3,726
    Hickory NC
    125 dB and I believe it.
  19. Crankit
    Crankit New Member
    18
    Nipomo, California
    Thanks Harry!!! I'll get a couple of those.. I suspect after who knows how many years that they did a little mix and match... Thanks for the prompt reply... Got no idea as how to ck. the DC offset???
  20. Crankit
    Crankit New Member
    18
    Nipomo, California
    Googled your fuse and it's a 4amp vs. 2 amp that I blew... I'll start there... Thanks Harry...
