Thanks for your quick response! Unfortunately it wasn’t the response I was looking for.
The sensitivity rating of a speaker is about how much of the signal will be reproduced by the speaker itself. This is a technical forum, some speakers are not designed for loud volume. Learn what technical specifications are for any given peice of equipment. There are plenty of online reviews to help you pick the right speakers, so if you don’t like those speakers....take them back for a refund !!
Also, if the capacitors in your receiver are not working properly that may also cause distortion at higher volume. So I would suggest taking the speakers back and having someone replace all the capacitors with something technically superior. Then learn about speakers and don’t expect to find a perfect match right away.
Steve Gottenberg is a great online stereo reviewer, read as many of his reviews as possible.
Also don’t expect a certain response because there are people that are like sharks on this forum and they will be circling for the attack !!
Sensitivity has nothing to do with how much of the signal will be reproduced. That would be frequency response.
Rather, sensitivity is a measurement of the sound pressure (loudness, measure in decibels/dB) produced by the speaker at a specified input (normally 2.83V, which is one watt with an impedance of 8 ohms, and 2 watts with an impedance of 4 ohms), at a specified distance (normally 1 meter).
A speaker with a sensitivity rating of 85dB and an impedance of 4 ohms - like the Elacs owned by the OP - requires four times as much power to achieve a given loudness when compared to a speaker with a sensitivity rating of 88dB and an impedance of 8 ohms.
The ELAC requires eight times the power vs a speaker with a sensitivity rating of 91dB and 8 ohm impedance.
As regards capacitors; I strongly disagree with your advice. These are new (or fairly new) speakers. The problems is almost assuredly not the crossover capacitors.
Talking about the capacitors in the receiver....
If a speaker requires eight times the power....how much signal does it require to produce the same sound ?
Enough said....
I have no idea what you are asking. Enough said.
halfway on the volume is not really 'anything', its not some sort of absolute. into a proper 8ohm load, by 12-1 oclock position, a standard audio taper machine is about the limits of clipping. IIRC only yamaha ever made an attempt to wiggle around this with an asymptotic volume control that theoretically could never hit this limit. and mind you, changing impedance throws the whole calculation out of whack. I have a mint set of HPM100As in the shop hooked up to an sx650 - not exactly a powerhouse and at 1/3 the volume on the dial the sound is very intrusive in a 8000sq ft store.If the receiver doesn’t have enough power, why do the speakers sound like they are going to blow up if I go halfway on the volume??
yeah, for all we know your speaker wire is not fart gas free.
If these speakers are low efficiency, like in the 80's and are 4ohms, it would be hard to find any situation where they can be driven properly.
To the OP:
We are here to help all! It clearly sounds like the 18 is running out of gas, if it is distorting at that low of a setting. Although you said it was in good shape, I do not think it is. 40 watts is not much power, For what ever reason your unit is only putting out 20 watts before it distorts. The 2265 is putting out 60 watts and working properly, This is only my opinion of course, but do come back and tell us what you find, We can all learn something.
