emresorkun
New Member
Hello!
I hope there will be someone experienced with passive preamps and connecting amps together can help me! I read a lot about this type of connections but I could not figure out if it is safe to do this.
This is recent my setup
A53 Creek Power Amplifier
OBH-22 Creek Passive Preamplifier
and an Onkyo TX-4500 Receiver and a Pioneer Sx-780
OBH-22 (passive) has Input 1 and 2 and also Tape in and Tape out inputs. According to the manual of OBH-22,
“For tape machines, use the Tape input and output - the tape monitor function will allow recordings to be made and played back. The output from the OBH 22 should be connected to a power amplifier with suitable sensitivity (gain). Remember, the OBH 22 will not increase the signal from input to output.”
I am planning to use input 1 and 2 for the Cd player and the dac as advised. And here comes the challenge! I would like to use one of my old boys (Onkyo or Pioneer) with this setup since I want to use phono section and tuner... But how?
Can I add my Onkyo Tx-4500 to this setup and use it with tape in of OBH 22?
Basically I will take signal from preout of Tx-4500 and connect the end of the RCA cables to Tape in of OBH-22.
So I will be using preamp of the onkyo with passive preamp of Creek.
And I also have this Sx-780. Nicely recapped..This one does not have pre out but I guess I can “tape out” this amp. I learned that when I tape out, Preamp of the amp is not used and,a 0 db signal is send. In this case the passive preamp will be placed between power amp and Sx-780.
My questions are,
If you would have any idea and any recommendation i would be more than happy to read!
Thank you!
My questions are,
- Which option is safer? Preamp the Onkyo or tape out the Pioneer?
- Which option will give cleaner sound?
Thank you!
