USMC Spike
Well-Known Member
This thread will discuss the changes necessary to convert the AD797 Moving Coil (MC) phono preamp to
use a Moving Magnet (MM) cartridge.
Hypno Toad worked to create the design of both the AD797MCPRE Printed Circuit Board (PCB) and a MMPRE PCB. These are through hole designed boards.
AD797 thread located here:
http://audiokarma.org/forums/index.php?threads/ad797-phono-stage-build-and-help-desk-thread.501186/
MM thread located here:
http://www.audiokarma.org/forums/in...igh-end-phono-stage-no-expense-spared.371889/
sacgu888 worked to have these boards produced along with a power supply board
for AK members, here is the LINK
My inquiry started with this post:
http://audiokarma.org/forums/index....help-desk-thread.501186/page-71#post-12273730
followed by some additional questions, answers, suggestions, etc.
Wyn Palmer, a retired Analog Devices, Inc. engineer, graciously suggested we create a new thread.
Here is a summary of previous information:
Is there a way to adjust the gain of this Phono amp so that It can be used with
a MM Ortefon red cartridge? Specs as follows:
Output: 5.5 mV
Frequ at -3dB: 20-22000 Hz.
The following are recommended:
Load R: 47kOhms
Load C:150-300 pf
Devices in my inventory:
AD797
LME49990
LME49870
LME49710HA
LME49720HA
LT1115
LT1028
LT1128
LT1468
OPA 134
OPA2134
OPA1641
I've read the RIAA Phono Preamplifier section from Jung, W. (2002). Op Amp Applications,
Analog Devices, Inc. (ch 6.11 - 6.27). While it's good background material, it's not applicable to this discussion.
My turntable is nothing fancy, a working Thorens TD-147, not currently in my system
as it's slated for electrolytic cap replacement and cartridge fitting.
The cartridge I've chosen is suitable for a reentry into vinyl of which I have one milk
crate left of various LPs. The cartridge specs follow:
Ortefon Red MM Cartridge
Output: 5.5 mV
Freq at -3dB: 20-22000 Hz.
Load R: 47kOhms
Load C:150-300 pf
Well, if you want I can explain the differences between the various approaches in terms of overload etc. and give detailed instructions on how to convert the AD797 board to the mixed design. I've done this previously for a friend who wanted a 2.5mv input configuration and I could easily do it for 5.5mv.
If you want you could start a new thread. I redesigned/explained in detail the Leach MC preamp for someone before and it was done in a new thread.
http://audiokarma.org/forums/index.php?threads/the-leach-moving-coil-pre-preamp.838004/
Output: 5.5 mV
Load R: 47kOhms
Load C:150-300 pf
AD797
LME49990
LME49870
LME49710HA
LME49720HA
LT1115
LT1028
LT1128
LT1468
OPA 134
OPA2134
OPA1641
Output: 5.5 mV
Load R: 47kOhms
Load C:150-300 pf
