Counterfeit 2SC2240
Discussion in 'Solid State' started by tarior, Mar 2, 2010.
  1. tarior
    tarior Dirty pool, old man?
    5,270
    Kelso, Washington
    I was working on a customer's Marantz 140 today, and I wanted to replace the differntial input pair with some 2SC2240 transistors. I got to looking at what I had, and they were very different from each other.
    The one on the right is a genuine Toshiba part from Mouser. The one on the left is an apparent fake, I'm not sure where it came from. It's pretty sad when the Chinese are counterfeiting 20 cent transistors.
  2. Stuart Pedaso
    Stuart Pedaso In too deep Subscriber
    1,174
    Solano County
    Care to crack a couple open to compare dies?
  3. tarior
    5,270
    Kelso, Washington
    The dies appear to be similar sized, the pinout is NOT correct. It really pains me to wreck a perfectly good transistor, BTW.:sigh:
    Again, Toshiba part on the right, fake on the left. It's hard to tell without a magnifier, but the Toshiba is better quality. Note the discoloration about the die on the fake part.
  4. glen65
    glen65 Member
    4,276
    Richland county, Ohio
    It appears that one is also a different pin out.
  5. avionic
    avionic " Black Knights" Subscriber
    35,871
    Fort Dodge, Iowa
  6. ecluser
    ecluser Super Member
    3,219
    When we want a 2SC2240, we don't just want a transistor that work in a circuit, we want a low noise transistor.
    Yes, the Chinese are counterfeiting 20 cent transistors.
    I can send you a 2SC2240 that will not work. I bought six 2SC2240 from a local parts store (by chance they had only 6 in their stock!) and when I tried to match them, I couldn't measure their hFE, no matter what pin-out I tried.
    I put them on my beloved curve tracer and it turns out that all of them were very bad PNPs !!!
    Since this misadventure, I never buy transistors from this store (ÉlectroMike in Québec city).
    In the picture on the first post, we can see that the left one is labeled c2240 Y. As I know, the hFE classification for the 2SC2240 is GR or BL. I didn't check all the datasheets for the 2SC2240 to see if some manufacturers use the Y classification...
  7. avionic
    35,871
    Fort Dodge, Iowa
    I get all my japanese tranny's at BDent haven't had a lick of problems. But I usuaully match up the suffix codes as well BL,GR. etc. BD has a very large selection. They also have a $15 min. order so I usually end up buying extra quantities..
    http://www.bdent.com/
  8. glen65
    glen65 Member
    4,276
    PNP?
    Wow..I guess they did screw them up.
    Don't know if you would be interested but Fairchild make
    a direct low noise replacement for these, KSC1845.
    http://www.fairchildsemi.com/ds/KS/KSC1845.pdf
    You could probably get some samples and give them a shot.
    So far Ive had no problems with them myself.
  9. avionic
    35,871
    Fort Dodge, Iowa
    I only see GR and BL...
  10. tarior
    5,270
    Kelso, Washington
    Like ecluser said, I want the 2240 that Toshiba shows a datasheet for. If the pinout is different than Toshiba's datasheet, it's phony part as far as I'm concerned. Furthermore, what are the chances that these things are going to meet the proper noise, current, voltage and cutoff specs? I'm betting slim to none. They aren't identical or interchangeable, and I'm sure as heck not gonna stake my reputation on them.
    As an example on the same topic, I keep Toshiba 2SC2383 on hand for a good all around replacement NPN. I've also bought Fairchild KSC2383, and you know what? Their spec sheet is practically identical to Toshiba's. Pinout, current, voltage, everything. In this case, these are basically the same transistor from two different mfrs.
    A tech can do a hundred perfect jobs in row, but the one people will talk about is the one that turned to shit because of bad parts.
  11. tarior
    5,270
    Kelso, Washington
    I actually ended up using KSC1845 in this case, but it only has half the current capacity of 2SC2240. I'm ordering new Toshiba 2SC2240s from Mouser in the morning.
  12. dr*audio
    18,124
    Cleveland, Ohio
    I bought my 2SC2240's from MCM Electronics, and they have BL on them. The HFE measures around 380.
  13. avionic
    35,871
    Fort Dodge, Iowa
    A noisy transistor I would not consider working... I was just stating that there are other companys legit or not unloading these on the market.And obviously there is junk out there.
  14. tarior
    5,270
    Kelso, Washington
    Most likely the real deal, and you can tell by the lettering.
  15. tarior
    5,270
    Kelso, Washington
    With all due respect to you, in this case if it's not Toshiba, it's a junk fake as far as I'm concerned.
  16. avionic
    35,871
    Fort Dodge, Iowa
    Concur...:yes:
  17. glen65
    glen65 Member
    4,276
    I'm not sure if I've used those before. But I like to keep something
    on hand that will replace a number of devices.
    You got it,
    All it takes is one mistake and all of the sudden your work sucks.
    I had one amp that gave out. Fortunately it was during the time
    I was stress testing it on the bench. Come to find out that two
    of the outputs were counterfeit. I bought them from some place
    called Audio lab Of GA.
    You wont have any problem with those guys.
  18. dr*audio
    18,124
    Cleveland, Ohio
    Glen, thanks for the heads up on Audiolab of Georgia. I have ordered parts from them before (IC's) and now I will use them as a last resort, if at all.
  19. tarior
    5,270
    Kelso, Washington
    Hmmm...I've always heard good things about Audiolab of GA, and have bought from them in the past. I sure hope it was a fluke.
  20. glen65
    glen65 Member
    4,276
    Ive seen the reports go both ways.
    Their service (at least for me) was fine.
    They even took some semis in on exchange once.
    However their product was another matter.
    I ordered product from them more than once
    because they had something the others didn't
    at the time. It turned out to be a bad move on my part.
    So I have completely crossed them off my list.
