I recently agreed to buy an SA-3 preamp as a project. It actually has a 3.1 board set in it, which is a good thing. Cosmetically it's in great condition, single local owner since new in ~1986, and it sounded wonderful during a brief demo with a Classe amp and Minimus 7 speakers. Initially, I thought it just had a balance control problem which we immediately heard during that demo, but I discovered at home that it was a deeper issue. Two of the four resistors pictured below were blown essentially open, while the other two measured extremely high.
Anyone familiar with this preamp model knows that the power supply voltages generally red-lined some of the power supply components, and with wall voltages frequently near 125+ VAC around here it's extra-hard on everything. Once I get the bad resistors replaced, I'll be checking the upstream components and will also replace them if required. Capacitors in particular will get replaced with higher-rated parts where needed. I'll be running it through a variac to drop the line voltage slightly. I'm hopeful it will be a fairly simple repair, compared to what Counterpoint amps need when they have issues.
I know Counterpoint's reputation for reliability is not very good, but this is simply the best-sounding tube preamp I've heard for the money and I'd like to get it in reasonable working shape again. I believe that part of reason it sounds so good because of the way it pushes the envelope. When it's repaird, I'll decide how much to invest in upgrading the 3uF and .47uF caps in the line and phono stages (mostly because they don't match each other that well between channels). It runs 6922 tubes by design, and these appear to be original Ei tubes @ 32 years old, so I'm thinking of upgrading to Siemens 6922/ECC82 or Amperex gold-pin 7308 -- note there is one tube for the line stage and one tube per channel for MM stage.
If anyone has any experience upgrading or repairing this preamp, I'd be curious to hear what you've discovered in the process.
