Thatch_Ear said:
You can put some light sockets on a board in parallel and the higher the wattage bulb and the more that are in the sockets will result in greater voltage drop. A quick trip to the lumber and hardware store and a bit of time you can build something that will do the same job as a variac. Just put the sockets in a chain and wire up a plug at the other end. With a voltmeter you can adjust the voltage through the number of and wattage of the light bulbs.
Not as easy to use as a variac, the result is the same.
You don't use the bulbs in parallel, and you only need one.
The other thing is the lower the wattage the higher the resistance.
Get your self a light socket, A duplex receptical, and a power cord, some wire, and I added a GFIC in front to make it as idiot proof as possible. possibly better than a light socket is an old fashoned screw in fuse holder. Yes they still make them! :yes:
Wire the power cord to the GFIC, (white to solver screw, Black to gold) or if you choose not to use the GFIC, Wire the black to one post on the light socket (Or if using a GFIC, use a wire from the side of the GFIC that goes to other circuits to be protected to the lamp socket). Wire the other light socket post to the gold screw on the duplex (putting the lamp in series). The white wire on the power cord (or the White side of the GFIC) goes to the silver screw on the duplex.
Now anything plugged into the dupex has the lamp in the socket as a resistor in series. I like having the GFIC as it also give me a handy full power outlet where I'm working. Be sure to mark the recepticals so you know what your plugging into. :yes:
You will also find the lower the voltage the less power a tub amp puts out. :scratch2:
Low lamp values give high resistance and lower voltage. high lamp values give low resistance and higher voltage,
I measured some at load and got these results:
Dim bulb tester - Bulb ratings and results.
Load Motorola Mono Tube amp, .62 @ 117VAC
bulb wattage ohms resistance resulting Voltage @121VAC input
40 26 67
60 19 81
100 10 91
150 7.5 100
240 5 110
This wont line up in colums but you get the idea...
I'd start with the 40 to begin.
