punprankster
Super Member
ATM I'm alternatng between a Sony CDP-8ESD and a Denon DVD910 for use as my primary CD player. Will I benefit from a dedicated DAC? How importnat is it to a system?
If you are using an older CDP, yes, a newer DAC will make it sound way better. That is without a doubt.
I think DAC's are a tough nut to grade. If the CDP that your using has a crappy DAC chipset or a lousy audio output amp built in than most any out board DAC will be an improvement. On the other hand if your CDP has good quality components and is carefully designed it might take a very expensive DAC to hear an improvement.
One suggestion I will make if all you listen to is CD's is to look at some of the older DAC's from the early 90's. Units like the Parasound D/AC-1000 can sound amazing.
BillWojo
I totally disagree due to the older filters compared to what are used now and the DAC chips. a purposefully built DAC will help ANY older CD player. Any CD player that oversamples and DAC that oversamples is part of the issue.
Not any more. There is plenty of information on https://www.computeraudiophile.com . They talk about the difference of the older filters versus the new ones. The older ones were more complex and oft times caused more issues than what they were originally trying to fix. Most newer filters start at a certain frequency and then then cut.
With DAC's - newer is better period. My experience and others too - again read the above website for info on filters. They have many actual DAC designers posting info there.
...everyone is entitled to their opinion and yours is just as valid as anyone else's. It doesn't make anyone right or wrong.
Prove it, show me. Nobody owns a 'stranglehold' on what real, natural music is suppose to sound like. You can bombard me with numbers, but again, they don't tell the whole story as to what is pleasurable to listen to, and what is not. In the end, I'm in love with the music not the equipment whatever gets me closer to this feeling is best. What I found, time and again, is that it's usually the older equipment with obsolete technology that gets me there.You need to rethink this (the validity and truth portions).
Genius! Just say you have nothing useful to add at this point- unless you do.Can't help folks who slept through PHIL101...
The truth in audio, if there is any truth to be had, comes from 'the listening' nothing else.Difference between personal preference and truth claims. You might want to think about that. It's an important distinction that, once understood, will vastly improve your ability to converse intelligently and civilly with others.
