Archguy
Official Roiurama Factory Rep
Greetings all: Just purchased this Denon amp because I am weak in the presence of beauty. Unfortunately it arrived with its front glass dislodged and one channel not playing. Fortunately Denon made the glass 1/4" thick back then so even though the amp was likely dropped in transit the glass didn't break. So I've glued it back in place and that seems okay. The shipper did package the amp properly.
The other issue is a bit more involved. I really don't want to send the amp back because it weighs a ton and I like it aside from the fact that it's broken. I found two ways to make the right channel play, once I hooked up the amp and tried it out. First, adjusting the input pot and second, twisting the RCA jack. Weird to me that both of those manipulations should produce the desired result. Well, sort of. It's very touchy and if you jiggle either just slightly the sound cuts out again.
The good news is that the sound is good. Powerful and with real presence. Right away I thought, deoxit on the pot right? But (see photo below) I can see no way of opening it up even. Advice anyone??
