^^^ +1 stickman probably has it right on. Although the potentiometer DA used for the tweeter level appears pretty robust, I've read on this board and elsewhere the potentiometer is prone to intermittent operation and requires cleaning. From my own experience cleaning did
^^^ +1 stickman probably has it right on. Although the potentiometer DA used for the tweeter level appears pretty robust, I've read on this board and elsewhere the potentiometer is prone to intermittent operation and requires cleaning. From my own experience cleaning did NOT work. I put an ohmmeter on the pot and rather than a smooth resistance change when moving the control, the resistance was jumping and as I approached 1/8 turn from minimum resistance on the pot, the pot would go open. Even after a repeated cleaning/treatment with Deoxit. The resistance measurements exactly coincided with what I was hearing. PE has a 15 Watt version of the potentiometer that is a very close match. Unfortunately for me, the tweeter was still dull/distant sounding with a new potentiometer. I finally went to the auction site (as suggested above) and bought a good used one. That fixed my final issue. I concur with GD70 too-- they are quite good sounding speakers for what they are. That small footprint is a big plus for locating them. Most original PS-10's will need to have the woofers refoamed by now too. The typical foam rot issue. The replacement surrounds are widely available. Carry on....
BTW- I did a recap on a pair of PS-10 crossovers. Just for S's&G's I measured the capacitance and ESR values on the original caps. All the original caps measured within tolerance for capacitance and the ESR was well under .5 ohms also. The crossover capacitors may be the last place to do your troubleshooting based on my experience. Just FYI.
