Been planning this for a while but I did not want to try it on any of my carts that actually worked.. Anyway the cantilever on my Ortofon VMS 30 was bent since I got it and worn stylus too so it was a perfect candidate for a test retip
First I cut off the bent cantilever leaving a stub. Next I cut donor conical cantilever. This will not be permanent I will be removing this again and fitting something like a AT vm95 ml stylus. Anyway the cheap conical first, with larger tube it slid nicely over the stub, happily the AT has a finer cantilever so it hopefully will slide inside without a splint. Anyway into position I did not want to glue in a way that cant be removed so a tiny droplet of nail varnish so little that it can be removed and not so little that it might not hold. Aligned perfectly, just low riding slightly as only glued top edge and I was happy to let it sit this way for a test as long as secure. Also tracking force needed 0.5g more for cheap conical. Next retip this wont be an issue.
Here are the pics
Here are the pics
