MtnBeachBum
Hello all.
Been chasing gremlins in my system since I moved to the new place. Ever since I set up the stereo system I swear that the left channel wasn't quite up to snuff with the right channel. I thought it was a speaker issue, probably because I have been wanting to upgrade the speakers for some time anyway. Then I noticed that everything sounded fine when playing cassettes. I then tried my other turntable and everything sounded fantastic!
I then turned my focus to the receiver because it hasn't had any work done to it since I purchased it. It has two phono inputs, so I swapped the inputs and plugged the Dual 701 into the Elac 50H inputs and still no left channel. So, now I know that it is a problem with the Dual 701 somewhere. I deoxed the pins coming out of the cartridge, the pins coming out of headshell insert, and the actual headshell itself, still no left channel.
My question to yall is what else should I concentrate on that may explain no left channel? I had a new RCA cable put on a year ago, I would be very surprised if it was bad already. I removed the 701 from the base for the first time ever to see if there was anything visually that looked odd but to no avail. I just had the turntable serviced a couple of months ago. I am hoping it's something simple I can do, I don't have any soldering skills or test equipment. Any ideas?
Chris
Chris
