Hi all, I have some questions about lack of treble response from my Dual turntable. I think its made 1984.
Many years ago a neighbour gave me a defect Dual CS 505-4 , it has been sitting in my attic for a decade or more until I decided to try make it sing again.
The turntable was spinning, but with speed issues and strong hum in the right channel.
It was quite an easy fix, a good cleaning and lubing, replaced drive- and pitch belt, new signal cable and rca connections, even changed the tone arm internal cabling with new silver leads.
Couldn't resist getting a custom plinth and an external riaa amplifier = Nad PP-2e
Adjusted needle weight around 1,3 grams (tried everything from 1 to 2 grams) and anti skating as good as I can get it.
Bass and midrange is good and no distortion. Both channels, no issues, plays loud and clear. Silent between tracks, no hum or motor noise.
BUT TREBLE is weak! Same in both channels. I have to turn treble on my pre to max to get decent responce. Its still too dull and muffled. Lacks detail and information in the high range.
Could the stylus be 'worn out' ?
Do the MM type cartridges get weaker in time?
Bad combo of riaa and cartrigde?
What brand is the pick up, do Dual make their own?
What do you think?
Best regards
KO
some pics
What do you think?
Best regards
KO
some pics
