Hey Gordon~ !! Nice to hear from you. Oddly, I just thought about doing the same thing, only I did it on the FM-2. I got as far as seeing the same 285 that you did, but then decided to also check the specs on the 6V4 Rectifier. Appears that's good for about 90 ma. The little Champ circuit I posted above is sadly missing the voltage specs.....so I'm going to have to do some swagging at it. That said, I did find a similar era amp, the Princeton, which does show some voltages. According to that schematic, the voltage going to the OT is 305. Fortunately, it also shows the cathode resistor (470 ohm) as having 19 volts on it. If I'm doing my math correctly, that means that there's about a 40 ma current draw on the output tube. Pretty 'hot' for a 6V6, eh? Anyway, I'm thinking that even if I'm down to around 250 volts going 'in' to the Output Transformer, I can try to emulate the same kind of 'ratio' used in the Champ's circuit with the Screen Grid having the the same B+ going to it as is going to the OT. Assuming the DC resistance in the OT will eat up some of the voltage going to it, I also assume the Screen will actually have a higher voltage than the plate? Anyway, hopefully I can just adjust the cathode resistor and still get the same basic bias current draw. Or, 'close' anyway. Actually, I don't think it would hurt the amp if it were even a bit less. Probably good for the tube anyway! These old circuits are known for being 'crunchy'.... which I think is somewhat dependent on this output stage being run hot like it is. At least I believe I'm in good shape using the PA-509 for the PT in this project!
Many thanks to Tom, Mike, and you for the help!! Best wishes over the holidays!!
Tom D.
