Dynaco ST-410 ....... OMG !!!
Discussion in 'Solid State' started by Foneman13, May 3, 2008.
  1. Foneman13
    Foneman13 Active Member
    121
    While waiting to receive a Knight integrated tube amp, and a Kenwood tube receiver, both purchased to feed my original Heresy's .....the Audio Fairy hooked me up with a super clean Dynaco 410 for $50 ----I KNOW !!!!----
    how blessed am I ??!??....
    So, I hooked it up with my Advent receiver as a pre-amp, and NOW I understand how BIG POWER shows up at low volume levels.....
  2. hypertone
    hypertone Keepin' it Analog
    2,948
    Vancouver Island
    Nice. I'd love to score a Dynaco power amp. $50 is a steal for one of those.
  3. Tromatic
    Tromatic Super Member
    1,290
    Portland OR
    Can you explain? 1 watt is 1 watt.
  4. Foneman13
    121
    NO, I can not explain it !!!!...
    Can you?....I am certainly interested in understanding this experience....Are you implying that I am fallen subject to the
    PLACEBO EFFECT ?
    Not that there is anything wrong with that:banana::banana::banana:
  5. Tromatic
    1,290
    Portland OR
    No, trying to understand how having big watts on tap translates to low volume.
  6. Marantz 500
    Marantz 500 Active Member
    492
    Sweden
    The amplifier's damping factor has to do with it:
    "UNDERSTANDING DAMPING FACTOR
    Loudspeakers have a mind of their own. You send them a signal and they add their own twist to it. They keep on vibrating after the signal has stopped, due to inertia. That's called "ringing" or "time smearing."
    In other words, the speaker produces sound waves that are not part of the original signal.
    Suppose the incoming signal is a "tight" kick drum with a short attack and decay in its signal envelope.
    When the kick-drum signal stops, the speaker continues to vibrate. The cone bounces back and forth in its suspension. So that nice, snappy kick drum turns into a boomy throb. Fortunately, a power amplifier can exert control over the loudspeaker and prevent ringing. Damping is the ability of a power amplifier to control loudspeaker motion. It's measured in Damping Factor, which is load impedance divided by amplifier output impedance. Let's explain.
    If the speaker impedance is 8 ohms, and the amplifier output impedance is 0.01 ohms, the damping factor is 800. That's a simplication. Since the speaker impedance and amplifier output impedance vary with fre-
    quency, so does the damping factor. Also, the impedance of the speaker cable affects damping. Thick cables (with low AWG) allow more damping than thin cables with (high AWG). The lower the amplifier's output impedance, the higher the damping factor, and the tighter the sound is. A damping factor of 1000 or greater is considered high. High damping factor equals tight bass.
    How It Works
    How does an amplifier control speaker motion? When the loudspeaker cone vibrates, it acts like a microphone, generating a signal from its voice coil. This signal generated by the speaker is called back EMF (back Electro Motive Force). It travels through the speaker cable back into the amplifier output, then returns to the speaker. Since back EMF is in opposite polarity with the speaker's motion, back EMF impedes or damps the speaker's ringing.
    The smaller the amp's output impedance, the greater is the effect of back EMF on the speaker's motion. An amplifier with low output impedance does not impede the back EMF, so the back EMF drives the loud-
    speaker with a relatively strong signal that works against the speaker's motion. When the speaker cone moves out, the back EMF pulls the speaker in, and vice versa. In short, the loudspeaker damps itself through the amplifier output circuitry. The lower the impedance of that output circuitry, the more the back EMF can control the speaker's ringing.
    To prove it to yourself, take a woofer that is not connected to anything. Put your ear next to the cone and tap on it. You might hear a low-pitched "bongggg" if the speaker itself is poorly damped. Now short the
    speaker terminals and tap again. You should hear a tighter thump.
    Damping factor varies with frequency. As you might suspect, damping factor is most important at low frequencies, say 10 Hz to 400 Hz."
  7. Tromatic
    1,290
    Portland OR
    What does a high WPC rating have to do with damping?
  8. Marantz 500
    492
    Sweden
    A more powerful amp usually has a much higher damping factor than a lower-powered one.
  9. grateful
    grateful Super Member
    3,068
    Mass
    You may have learned something. The very clean wide bandwith Dyna will grossly outperform most any tube amp.
  10. Alan NY
    Alan NY Active Member
    223
    Stanfordville, NY
    thanks Marantz
    Very well explained! :thmbsp:
  11. grateful
    3,068
    Mass
    The only thing wrong with the explaination is the speaker wire negates the whole theory of the damping factor having much control over the sound. Speaker wire resistance is many magnitudes higher than the amps source impedance. This makes the effective damping factor in the whole system very low regardless of the amps very high damping factor.
  12. Marantz 500
    492
    Sweden
    Doesn't that depend on the length and properties of the speaker cables used? And wouldn't an amp with a low damping factor to start with be affected in the same way by speaker cable resistance, lowering damping factor even more?
    I am no expert, I just find that there IS (can be) a big sound quality difference using a more powerful amp compared to a smaller one, even if you're not playing very loud, and the damping factor explanation seemed to make sense to me.
  13. grateful
    3,068
    Mass
    Well yes but the great qualities of a super amp are realized with regular zip cord speaker cable. 3 meters of 16 gauge adds about .4 ohms. Your explaination of damping factor is great but I don't think it is the reason super amps sound so great. Of couse some tube amps have damping factors of 10 or so. This can't be good for tight quality bass.
  14. dshoaf
    9,659
    Santa Cruz, CA
    Ignoring the Damping Factor wars, which has been well-discussed elsewhere, back to the thread......
    That sense of effortlessness from a big amp can be quite compelling, especiallly if its your first experience with it and with efficient speakers like yours Foneman, it will be even more pronounced.
    While I still like my tube amps, I do like hooking up the old, road-weary Hafler P500 (250wpc) occasionally to my JBL or UREI studio monitors for fun. Its a nice effect but can, and will likely, wear off over time.
    If you choose to keep the Dynaco, however, get it serviced as there are old parts in there. At the least, fuse your speakers.
    Cheers,
    David
  15. Marantz 500
    492
    Sweden
    I can't really choose between high power SS and tubes, so I use both in different systems/rooms. I find that my Quad II amps and my Dynaco ST70 are great for listening to classical and jazz, but they dont't excel when it comes to pop/rock music, at least in my system. For pop/rock I much prefer my Kenwood Basic M2, Nikko Alpha 440 or Marantz 170 DC power amp. And I do have too many amps (can't use them all at the same time)... I was on the verge of buying a Dynaco ST410 a month ago, but the deal fell through - seems to be a cool amp!
  16. grateful
    3,068
    Mass
    I also have many amps. My Crown Ce2000 sounds better than any amp I have ever owned including A Marantz 8b Dyna 410 etc. I have AR 11s for my speakers. I think it sounds better with all types of music. Cleaner and more transparent.
  17. Marantz 500
    492
    Sweden
    I use AR-12 speakers, of the same vintage as your AR-11's. Would love to have a pair of AR-11, but the AR-12's still sound very good! Are you bothered by fan noise at all with your Crown amp, or is it a quiet fan?
  18. grateful
    3,068
    Mass
    There is no fan noise at all. It never comes on. There is almost 2000 watts available the sound is clean and totally effortless. I am a bit of an AR collector. I have a pair of 9s, 10 pi ,98ls, 3a, 2ax etc. In some ways I like the 11 the best. The 12 is another I would like to get in my collection.
  19. Marantz 500
    492
    Sweden
    Wow, that's quite an AR collection! Speakers from the "Truth in listening" series seem much less common than earlier models. I find the AR-12's are my best speakers so far, (not that I've had any real high end stuff), but they just sound right! A friend of mine has AR2ax speakers, and those sound beautiful as well. The Crown amp seems extremely powerful, I'll have to check that one out.
    /Jake
  20. grateful
    3,068
    Mass
    Many audiophiles have been to my house, the ones that really have an ear for music are astounded by the sound of the AR speakers. I think they are about as good as it gets at reproducing the concert hall sound. I like the look of the classics like the 3A but I think the 11 is when AR completely refined the design and got it perfect.
