Dmannnnn
Up Late
I had been waiting what seemed like forever for parts to arrive for the lafayette 224 I was going to tackle as my first restoration. Sure enough an HF-81 caught my eye on the auction site and I bit. Here are the auction pics.
A little rough, but still intact and no major problems. A previous owner drilled a hole in the faceplate for a power switch, Ouch! I will obviously need to keep a switch there, but for what I don't know yet. It appears to have the complete original tube set of eico branded mullards. I powered it up when it arrived and it seemed to be running OK but not sounding great and not too loud. The pots are all filthy and I'm still not sure if any of them can be salvaged.
Anyone who has ever worked on a one hundred+ year old house will know that once you start digging it isn't good, you keep finding more and more problems. Well I installed a new power cord, started to pull old caps and soon realized that this amp needed serious help. It is obviously kit-built and very poorly at that. After pulling bad wire after bad wire and having a second tube socket lug break off, I just pulled it all out, every bit. So it will be a ground up restoration.
Wouldn't you know it, two days later while searching for information on the amp I found one listed across the country on craigslist. I contacted the seller and made a deal. I figured I could do the work simultaneously and possibly end up with a pair of mono HF-81's! Here is a pic of the second unit.
When it arrived I realized the second unit was a very early model (serial no. 2216) and had a couple differences. The mode switch only has three positions (stereo, reverse, and mono) and on the horizontal inputs there is a fourth unused jack for the right channel. Those seem to be the only differences. It was also beautifully assembled. It came with a purchase receipt (April fool's day 1960), a full size schematic, an assembly manual complete with 3 separate pages of addenda, a front panel template for console mounting, and an unused chassis sticker with the input schema. This one should just be a simple cleaning and recap.
Sorry for the longish intro. I will be documenting the rebuild of the first unit in this thread. Any input is appreciated as this is the first time I have done this.
