xbart
Super Member
Picked up this Eico ST 70 two weeks ago.
Starting to clean it up and come up with a game plan.
The outside is pretty nice, inside a lot of dust. Undersides look OK, with no obvious damage.
Being that it looks pretty nice, I'm thinking that I'll do a basic recap and a fix a few known flaws and give it a listen.
I have a lot of the needed caps on hand and I have re-stuff the old metal twist lock cans in the past.
The original can for the first couple stages of power supply filtering is a 40/20uF 500V and I don't have any 500V caps that will fit inside the old can. So looking at my options, I could use a snap-in 50/50uF 500V from the likes of JJ, F&T or a twist lock from CE Mfg. The CE twist lock caps are 3 times the cost of the snap-in caps, any reason to stay away from one of the snap-in caps other that looks, is there a quality difference?
I also notice that there is a -10 to +30% tolerance on the 50/50uF cap. If it much higher than 50uF, it might be a issue for the rectifier.
Eico ST70 owners, I would like to hear your thoughts on this amp.
