The blue color indicates collisions between high-energy electrons and various elements, including metals, residual gas, and even the glass itself. Remember, not every electron contacts the plate and politely exits the tube; some go astray on the long journey to the plate, hanging out with a bad crowd, hitting the tube structures, while others bounce off the plate and ricochet around, eventually escaping and contacting the glass which is stimulated to glow. So the blue glow can arise in a number of ways.
Given how common the blue glow is, and the fact that the tubes test good, it is unlikely to be residual gas. Since the glow is in a particular spot related to the plate, that indicates a consistent path for photons emitted by the plate, but also electrons bouncing off the plate and hitting a structure or the glass stimulating emission. (The richochet phenomenon is why tetrode kink arises, and why the suppressor was created.) The blue color suggests possible emission from a structure made from fernico (tradename Kovar), an alloy primarily of iron (Fer from ferrous), nickel (Ni), and cobalt (Co) (hence the name), which possesses a low thermal coefficient of expansion. The trace cobalt will glow blue when stimulated. It might also be the glass.
In mercury rectifiers the gaseous mercury emits in the ultraviolet, so the low end of the spectrum glows a beautiful violet-blue color. But that is a totally different phenonenon.
