jvcforce
New Member
I've just purchased a very clean ELAC Miracord 50H II unit locally (I had to drive about an hour to pick up though.)
It came with an original documents; a user manual and a plinth cutout dimension.
Also it came with a plastic cover, auto changer rod and single play rod, all in very good condition.
Every function works. Auto changer works, and speed is very consistant.
However, it seems that tonearm pivot is a bit loose. Then I grab the tonearm and gently push and pull, I can feel a bit of looseness. My other turntables' tonearms are not loose at all, and I want to have it repaired.
Is it possible to repair the tonearm?
