Probably just big wirewound resistors. These are generally fine for most use, unless you want super detailed measurements of things. The bit of inductance they provide might skew measurements on extremely low distortion amps. If you just need something to connect for basic function tests, you're fine. Just be aware that if you pump a lot of power in, these will get quite hot.
