Hi everyone,
Been lurking for a while in the diy section and made scant posts in other places. I'm looking to tackle my first full recap on a sony str-6800sd, hopefully with AK's help. I've done the BillD C-1 mods to my carver preamp, I can solder well enough to get myself into trouble. I've got a meter, a signal gen and an oscope, although I haven't had occasion to try the signal gen / oscope. I've read through leestereo and cohibajoe's recap threads linked below for some basis about what to do.
http://audiokarma.org/forums/index....grade-of-unican-erics-sony-str-6800sd.550256/
http://audiokarma.org/forums/index.php?threads/sony-str-6800sd-recap.415389/
I just have a couple of questions before I start to make a parts list and start the recap.
1) Outside of the parts listed in Leestereo's thread, are there any diodes etc. I should replace for reliability?
2) When I acquired the receiver, the owner's had it hooked up / on. I checked the dc offset at the time, and it was somewhere around 400mv, I know this is high but in the partial service manual I found online, could not find what it should be. How should I go about troubleshooting this, or should I go through the recap and see where I end up?
3) Outside of the listed threads, are there any reasonable upgrades I want to consider? So far my plan is to order the same (or similar) parts as Leestereo did in his restoration. Should I also recap the FM board? Replace signal path resistors with metal film etc.? I don't have a set budget for the project and would rather only be in here doing an overhaul once. Depending on complexity I would need a fair amount of help to pick / choose parts.
4) Anything else I need to post up information wise for folks?
I'll be posting interior pics of the unit tonight when I get home.
