Afaik, yes, just two.Two stage?
Iirc, the sensitivity of the J is higher than other Alephs, but I cannot find that chart.
Btw, I already have a working example, I just haven't put it in yet since it arrived last August, flipping other amps thru to establish a baseline.
I shall. I have the option of a Conrad Johnson Motif MC-9 line stage if necessary from another system, but I'd rather keep the B-1 in this one.The gain shows to be 20dB for both J & standard versions on unbalanced inputs.
Just give it a try!
My mag phono has adjustable gain, so, like with varying CD levels, it may be sufficient on most if not all source material.When using the Aleph J and B1 with inefficient vintage speakers, I get enough gain when using a CD player, Chromecast, etc. When using a turntable and preamp it's borderline ok.
Dunno what that is, the Motif MC-9 is about as simple as a FET line stage with gain gets as an alternative to the B-1.I'm using an F5 I built with 32V rails. The 15.5dB of gain needs a little help to drive my Focal 936's at 90dB sensitive. If for whatever reason you're not getting the gain you need, just drop a BAGS on the B1 output. 6L6 has a good guide on using the BAGS stages in pre-amps.
