Mark Davis
What is every ones opinion on this receiver?
Any particular models jump out for the above mentioned other receivers? I know of a Kenwood kw-60 available. Not sure what a good price would be.Low power, hard to work on, hard to keep running right, dark sound,,,,,, Getting your hands on a good vintage Fisher receiver is not so easy as you might think. There are lots of reasons for that . And the ones you really want are very pricey for what you get when compared to the other brands of the day. Many things come together to make a unit collectible and the Fisher has all the wrong ones if you want something you can get for a reasonable amount of money and actually use day in and day out. It's a tube era leftover. Plenty of 1966/1972 30 to 50 watt Pioneer, Kenwood, Heath, Sansui, Lafayette, Magnavox, JVC, Allied, Scott, Sony,,,,,,,, for a 1/4 the cost plug and play. All sound great with excellent build.
Popcorn time.
Whay are your thoughts on a Technics SA-303 Stereo Receiver for $80? In great condition?I sold a lot of lower end Pioneers, Kenwoods, Sansuis, Technics, and others back in the early to mid '70's. The Technics were the most trouble free across the board, it was a rare one that had any issues at all out of the box. The lower end Kenwoods and Pioneers seemed to have a lot of soldering issues with regards to the volume/tone/balance controls, and some of the plugs that were hand soldered. The mid range and higher end ones were pretty good. I had a low end Kenwood, I don't remember the model number come out of the box and make no sound at all, except a very slight hum. The volume control wasn't connected! By that point I was trying to get my customers to move up to at least a lower end Kenwood, if they had a Kenwood thing going, same for Pioneer. The odd thing to me was that I had people buying stuff from me that seemed fixated that all their components had to be from the same manufacturer, but they would mix and match car speakers and when quad started for home gear, would buy one brand for the fronts and another for the rears. Since I had had a lot of problems with the low end Kenwood receivers and had gotten good at finding bad solder joints, I had no problem connecting the volume control and not have to send back the dead unit and wait for a replacement or repair, which took forever most of the time. My own HK330B took months to return from HK's service depot when it started sounding very dull, like my tweeters had blown. When it came back, it sounded better than it ever did, but I had moved on and replaced it with my long time unit, a Panasonic/Technics (I've seen them with both names, along with National) SA-6500. It's weak spot was the slide controls. Mine was working great after 30+ years, but the volume slider had become intermittent, so it became my surround power amp. At almost 46 years old, it's still working daily for a friend without any repairs except for me keying up a 300 watt linear amp next to it and blowing out the FM right after I bought it. A diode had it going again. I have one now that works pretty well, but needs filter caps, which I have ordered. And the Sansui receivers I sold were in general, nightmares. LOTS of bad soldering in them. I would run them for a week straight before sending one home with someone. A couple of years in, I stopped selling them unless someone really really really wanted one. Grey market warranty on Sansui's made for a world of hassle.
