I thought I'd never do it. Well, never say never!!!
I'm just going through the initial inspection and it seems like it has had very little, if any, work done on it, happily. The seller did advertise that it had the switch rebuilt and I could see that has been very nicely done. Because the tubes it came with weren't worth their shipping weight, I re-tubed it from my stash, brought it up on a variac since this morning, and fired it up using the power amp of a NAD receiver. So far the tuner circuit works as does Aux 1. Aux 2 had a very anemic left channel so I let it run unattended for an hour or so and that cleared it up. So far, only a couple of things are bugging me.....
Nothing I could do about it but some prior owner was a bit too aggressive in trying to clean the chassis. I suspect an abrasive buffing brush of some sort was used to clean the surface. It is obvious due to the scratches that clearly cut through the surface.
Another thing is that there is no serial number! I looked through a loop and see no evidence of a stamped number; nor do I see any indication that one was stenciled on.
Finally, for now, in addition to the face plate being much heavier than the plates of the receivers, pre, and tuner that I have, it looks like it has been heavily lacquered. I don't know if that is a factory detail or a "fix" by a prior owner. From what I've read, there was a lacquered brass faceplate, and a brushed (I believe plated) aluminum one for this model If someone can put me at ease on this detail, either way. I'd appreciate it.
While the unit came with a wooden case, it was not the correct cabinet. Since my new baby doesn't seem to need much electrical work, I think I'll spend these last warmish days on the table saw building a proper cabinet. To that end, does anyone have actual dimension front to back? I can figure out the rest.
That's it for now. But let me give a big shout out to xbart for providing the missing shields. Again, many thanks!!!!
